The Extech M0280 pinless moisture meter. It reads moisture in wood and other objects 3/4" deep into the object.
And that's white oak! Alright, I confess, that piece has been in the basement for 2+ months, and was split and stacked this time last year outside, and was standing deadwood when it was cut, I just wanted to see what the best I could hope for was.
It works pretty well I guess. My biggest issue with it is it constantly makes this chippy annoying noise while it's acquiring, my wife told me she was going to bust that thing if I didn't shut it up! The other issue with it is it really wants a 40mmx40mm (1.6"x1.6") flat spot where you can get the whole sensor on the back in contact with the object being tested, which on firewood can be a challenge.
I wanted the pinless because I wanted to use it for other things around the house, there's a couple spots where I suspect moisture behing things. And it has a 90%high range (on the right range setting). I put it to some fresh green white oak I just cut 2 weeks ago and it read 61%
Anyone else using this or other pinless models?
