I'm having draft issues with an Englander NC-30. I know there are questions about draft issues are all over this forum but I haven’t been able to figure mine out. A little background: It is attached to a masonry chimney lined with a 6 inch corrugated liner. The top of the chimney is about 20 feed from the floor the wood stove sits on. The house is surrounded by tall trees and is on a hill. Leaving windows open doesn't seem to make any difference, so I think I can rule out any negative pressure issues. The moisture reading on the wood was about 14% and I even have problems with drier wood. I rarely have any issue with down draft and smoke never enters the room when opening the door unless I open it too fast.
I've been able to get the fire going somewhat decently by opening and closing the door until I can get the stove top up to about 700. But even then once the fire is nearing the end and the flue temperature starts to drop the logs end up smoldering and large unburnt pieces are left.
Doing some research I considered "air inversion" as a possible issue, seeing as how any smoke coming from the chimney seems to drop down toward the ground. This happens more so than not. I'm also worried that with the NC-30 being so efficient, the lower temperature gases going up the flue may be amplifying any issue.
Right now, I'm not sure what to do next. The installer told me there shouldn't be any issue with the chimney. I'm not sure I believe that and was considering trying to temporarily extend the chimney to see if there's any difference. Can I jam some extra single wall into the corrugated liner?
I haven't really been burning much yet except on the nights it drops into the 30s. But I had this issue last year as well.
But even after taking the reading on a fresh split I got between 17 and 20%
