So now that I have my liner down the chimney I need to figure out how to get from the liner to the stove (Englander NC-30). My problem is that when the previous owner remodeled the house years ago they covered up the fireplace and because of our furniture layout I've decided to go in through the side of the chimney in the room adjacent to the old fireplace opening.
I've attached a picture of where I opened up a hole to where I need to connect to the liner. The "hole" is 7" wide by 9" high and the wall is just over 18" wide. The two pieces of wood running vertical are just furring strips that I can remove but the 2x lumber above will have to stay so if I need to cut into the chimney lower I can. I plan on placing the stove at a 45 degree angle in the corner.
I looked at the article on passing a chimney through the wall but I believe this situation is a little unique due to the clearances in the corner. I will need to be able to pass a 6" pipe through the chimney/wall to connect the liner to the stove. Thanks for any suggestions anyone can come up with.
![[Hearth.com] Need help figuring out how to go from my liner to the stove. [Hearth.com] Need help figuring out how to go from my liner to the stove.](https://www.hearth.com/talk/data/attachments/111/111830-7f1d24e979d959e0a3525a6c3319e1d0.jpg?hash=VfxmQkJTMm)
![[Hearth.com] Need help figuring out how to go from my liner to the stove. [Hearth.com] Need help figuring out how to go from my liner to the stove.](https://www.hearth.com/talk/data/attachments/112/112072-884293830fb8b00165ce1148fdaf6b5b.jpg?hash=8GE0cjrxx2)
