I'm trying to find an outdoor forced air wood burning furnace with a pellet backup any ideas where to start
You missed what I was talking about.....
Look up what a "heat exchanger" is... understand it's principles...
then you will understand how one would be used to accomplish
having forced hot air heat inside your abode.
What you’re talking about more understandably would be water to air units. As you describe he could put a 100,000 BTU exchanger in the hot air plenum of his furnace. I have no idea why anyone would want to go out in the cold and load them things.Thanks! Jrem,,
(Outdoor forced hot air system = impractical)(too much NRG loss)
However,
If you want to feed something like "mad" with wood. (and it needs to be outside)
You have a furnace outside (water is a better carrier of NRG than AIR)
You run the furnace heated water to the "plenum" inside your abode (if you don't know the term Plenum - look it up)
At this point (at the plenum)
You do a nice little exchange of NRG between Water(that is freakin' really hot!) and
Air(which is in your abode).....
So go ahead,,,,,,,,,,, pump that air around........
I know you like it.......... (that is forced hot air)
It doesn't know that it came from some pipes outside.......
(the heat has been exchanged)
The technical details have been left out.(simplifying the explanation, to make it easier to understand)
See if you can look up some pictures of "heat exchanger systems"
You may see some stuff called "heat pumps" (same principle --- slightly different)
look at some pictures... It will help to see.....
Extremely hot. A unit we were experimenting with actually melted the water line. Had a secondary run going to the garage ( 2 1/2 bay wide , double deep, and 13ft ceiling) used a rad out of Honda civic and box fan behind on low. Heated the garage so well we had to put a thermostats on to shut it downThanks! Jrem,,
However,
