I just joined the forum.  I have a situation where I need some advice.  This is likely to be a long introduction so please stay with me.  A year and a half ago we purchased a house.  We had a home inspection performed.  One of the items was cracks in the masonry crown of the chimney.  The recommendation was to have these repaired to prevent water entering the masonry and causing problems.  There was also some roofing concerns.  I had a reputable roofing company come out give me an estimate for the roof.  While they were here I asked if they did  crown repair.  They said no but they could fabricate a chimney cap that would prevent rain from entering the masonry.  I agreed.  They came out and did a great job on the roof.  They then came out with a man lift and installed a stainless steel cap.  This is when I began having problems.
We had gone one winter prior to having the cap installed. We live in a two story house with two fireplaces on the main floor and a thimble for a wood stove in the basement. The fireplace in the family room is equipped with an insert, buck I think, with glass doors. We use this to supplement the propane furnace. The second fireplace is in the bedroom and while it is functional we have never used it. The thimble is sealed . There are three separate flue tiles protruding from the chimney. The one to the family room is in the middle. Last year we had no issues with burning wood in the family room. This year with the chimney cap installed we are getting a smoke smell in the house. Not every time we have a fire but often enough to be a concern. I contacted the roofing company. They wanted to bring in a chimney company to evaluate my chimney as it may need cleaning or repair. I told them the previous owner had it cleaned prior to the sale a year and and a half ago. He had never had a problem with smoke and neither did we until the cap was installed, why would it be my chimney and not the cap.?
The roofing company came out today and reduced the height of the flue tiles thereby increasing the distance between the cap and the crown. I started a fire in the insert. It appeared to draw pretty well. I closed the door and the firebox filled with smoke. I opened it and it went up the chimney. I closed it and it filled again. The settings have not been changed. I went into the bedroom and there was visible smoke. We live in a valley and there is wind or a breeze daily. Today was windy and temperature 73 degrees. Can any one tell me the cause and what to do to fix it?
		 She's thinner than she used to be, though..
