I recently purchased the PH35PS stove and I am in need of some assistance. This is my first pellet stove so bare with me as I am still learning.
I purchased this particular model because the price point was right and the reviews are all fairly positive.
I have only had this stove installed for a week and I am already having problems. The stove starts up and ignites fine but after a few minutes the glass is covered in black soot. The termination cap on the vent pipe is also covered. The flame appears lazy and the burn pot will fill up with half burned pellets. It creates quite a mess and makes for some fun cleaning. From what I have read my stove is starving for air, however I am at a loss as to what to try next.
Here is my setup and what I have done:
Installation:
The stove is angled between two walls. It is vented horizontally straight through the wall-tee with one appliance adapter, one 45-degree bend, two feet of straight pipe and a horizontal termination cap. The vent pipe is 3” Selkirk VP type L. As per the instructions all connections have been siliconed with high temp RTV sealant including the connection at the stove.
I know some vertical pipe is recommended for draft but because of space restraints, I had to install it this way. The termination cap is 18” from my house and so far no soot has got onto my siding. I also have a UPS that will run my stove for several hours if I experience a power outage.
I have installed the outside air kit that came with the stove. My house is old and not extremely well sealed so I do not know if this was necessary but it was recommended so I installed it.
Wood Pellets:
So far I have tried 4 different brands of wood pellets. 1 hardwood, 3 softwood – all premium grade (low ash content, no chemicals etc, etc). Changing pellet brands has made no difference to the problem.
Stove Settings:
Changing the temperature control from min to max and everything in between has made no difference.
The thermostat sensor is on about 3 feet of wire and allows for different placements. As per some suggestions I found online, I moved this sensor but it did not help the problem.
The air supply on this model is electronically controlled via a small trim pot. I have followed the suggestions in the manual and tried it at all settings. Changing this does not appear to make much of a difference to anything.
The feed rate is not adjustable but the auger does NOT run continuously so I do not think this is a problem.
Rope Seals:
I used the match test to see if the seal around the door was leaking. It appears to be working as expected.
Cleaning:
I have been keeping the stove extremely clean as per the instructions in the manual.
Outside Air Kit:
Last night after running out of ideas, I tried disconnecting the OAK hose from the stove. The stove began running much better. Still some black soot but MUCH less than before. The flame also appears to be much more yellow than orange and more of the pellets are being burned. On inspection of the OAK hose it does not appear to be clogged at all.
I am stumped! I have contacted GHP customer support but I am still awaiting a response.
Does anyone have any suggestions as to what I should try next?
Thanks for your time,
Chris
Installation:
Wood Pellets:
Stove Settings:
Rope Seals:
Cleaning:
Outside Air Kit:
Chris
Did the OAK come with the stove or was it separate item? May want to contact the seller to identify issue...
