I have a Hearthstone Harvest soapstone stove built in 1990.  The flue gases are drawn into the cat chamber at the rear bottom of the firebox when the bypass damper is engaged.  I think this old design makes it more difficult to maintain an active cat on reloads.
The problem is that if I reload while the coal bed is still quite hot, I can reload and close the bypass damper in a minute or so and still have the cat lit. Over time, the temps rise in my house to where it is too hot.
If I let the coal bed burn down and then rake to front and reload, I need to wait quite a bit longer to engage the bypass damper (up to 45 minutes).
I just replaced the cat this year and really like not producing any smoke, but I just can't take the heat after a few reloads.
Also, a cold start takes a good 60 to 90 minutes before I can engage cat and get confirmed light off (cat probe temps over 500)
Any owners of older cat stoves similar to mine have this problem?
Any suggestions on how I can keep the cat active and maintain reasonable temperatures?
Thanks.
Thanks.
		 Couldn't save the stove, but did tear it down and save the soapstone.  They are a good heater, as you mentioned, the design is a bit different and probably a good reason for why hearthstone really didn't keep up with the line...... I just don't think they idle down as well as some other designs of cat stoves.
