I posted a few months ago but have a better idea of what was wrong. If I could delete the old post I would.
Yes, the installers did a terrible job sealing and insulating the B-Vent. My home has three decorative B-Vents (yuck), but the one in my basement is very leaky and keeps the basement freezing. My other two are very manageable in comparison. I have a wood stove but I can't afford to remove these B-Vents at this time.
The bump out was very leaky, no air-barrier, no caulk, loose fitted plywood, and big gaps pressed against the cedar siding (hidden by trim). Yes, this unit was an afterthought installed when previous owners finished the basement. Inside the bump out was insulation on the bottom half, nothing on the top half, and no drywall. (Was this the way these were installed back then for safety reasons?) I removed it, took off the siding, and removed the plywood sheathing.
The insulation was just stuffed in certain wall cavities, and one cavity had no insulation at all. I removed the old stuff and put in pink R-19. I'll seal it back up today, caulk any gaps, put siding back up and then tackle the bump out.
Per the manufacture the stove requires 1/2" clearance on all sides. I asked why it needed the clearance and they explained how B-Vents use the inside air for combustion. I asked why the exterior should matter and she explained it's for making up the air loss. But when I asked if it's okay I seal up the bump out they said that was fine. Wouldn't that do the same as removing the clearance (stopping the air exchange)? Or does the B-Vent need air to evenly come in from around its enclosure? This is the source of my cold air issues and I'd like to seal it as much as I can. Is the clearance a combustion issue?
The same person mentioned these bump outs are typically fully insulated on all sides and covered with drywall. Is the drywall important? I will be using Mineral Wool.
Thanks!
Thanks!
![[Hearth.com] Need quick advice re-insulating exterior of old B-Vent [Hearth.com] Need quick advice re-insulating exterior of old B-Vent](https://www.hearth.com/talk/data/attachments/320/320342-044f6c7614833c5ec3fee75113ea505c.jpg?hash=G8undKaaR4)
![[Hearth.com] Need quick advice re-insulating exterior of old B-Vent [Hearth.com] Need quick advice re-insulating exterior of old B-Vent](https://www.hearth.com/talk/data/attachments/320/320343-5b4a4f5fd102979e240de93947c62776.jpg?hash=BvgOiF7UUz)
![[Hearth.com] Need quick advice re-insulating exterior of old B-Vent [Hearth.com] Need quick advice re-insulating exterior of old B-Vent](https://www.hearth.com/talk/data/attachments/320/320344-8d6f333a2c24ff1a64f089f2dd15dcbf.jpg?hash=mLdS6TkGAR)
![[Hearth.com] Need quick advice re-insulating exterior of old B-Vent [Hearth.com] Need quick advice re-insulating exterior of old B-Vent](https://www.hearth.com/talk/data/attachments/320/320378-5d3d722173a59ef180ec115057fc519e.jpg?hash=ISB0-2rjki)
