M
Madcodger
Guest
Our new Quadrafire dealer (switched dealers for service this year) installed "updated" firmware from Quad in our stove when he cleaned it and prepped it for the season a couple of months back. He mentioned that it was designed to run the ignitor for less time in each startup cycle, thereby reducing the need to replace ignitors as often (our first lasted about three years). After running the stove for about 10 days now, I can tell you that this new firmware is just awful, and we have the dealer coming back later this week to put our old (last winter's) firmware back in.
We've found that, running the same pellets as last year (even the same batch / lot, as they are left over from the previous season) the following problems occur:
- Stove fails to ignite about every other morning, after being off all night (we get a low firepot temp warning, and it then works fine after pressing "Retry", an hour or more after the stove should have come on.
- The stove is designed to start backing off on flame intensity as the room approaches its target temperature, and this has worked well in the past. Now, it rarely even makes it to the target temp, with outside temps only in the '40s and '50s. It starts to back off about 2 - 3 degrees below target, and just runs at a very low flame intensity.
- The stove often (though not always) burns with a lazy, soot and ash producing flame, almost as if it were air starved. This happens as it backs down when it approaches the target temp. And this after a very thorough cleaning less than 10 bags ago (essentially torn down and cleaned as thoroughly as possible). Three days of burning produces as much ash as an entire week in the dead of winter last year!
- We're going through approximately twice the amount of pellets as this time last year, likely due to the very poor quality of the burn.
