So they just installed our new Clydesdale today and I have a couple of questions:
How many break-in fires do you need to do before going full throttle? I did one today and got the stove up to about 300 I believe—I put a stove top thermometer next to the leveling bolt under the grill—we have a cast iron version of the Clydesdale (left off the grill for the first one). Si I'm guessing that the temperature from that spot should be somewhat accurate. Hearthstone just mentions the one and getting the stove warm to the touch. I saw that Jotul suggests three break-in fires with each getting slightly warmer.
Two: is the bolt under the top grill a leveling bolt or really the draft sampling port? The installers said it was just for leveling the grill? mine just looks like a screw with a hole in the top. I thought I saw some references here that it is the draft sample port but also is used to level the grill.
Three. Don't think the guys who did the install leveled the insert using the rear leveling bolt at all, as before I started the fire I put a small level on the soapstone bottom and it was much lower in the back. They had a bit of a hard time getting the flue pipe in due to the height of the stove to the fireplace so not sure if they left it like that on purpose. It does seem to have a bit of a tilt to the back as when the door is open half way, it will just about close itself. Is this bad? I haven't paid for the installation yet, so I do have some leverage to have them come back.
With regard to the front leveling bolts, are they supposed to be extended to reach the hearth/floor? both were above the ground. I adjusted one and noticed that it shifts the protruding part up or down a bit, even though the bolt still doesn't touch the ground. I adjusted it a bit to make the appearance of the firebox to the surround look a bit more even.
Four: fan came on and I guess I had it all the way up. It was loud, but more concerning was a whistling noise. What might that be? When I turned it down, the whistle stopped and it did get quieter. There was one setting in between where it did sound like a bit of a aluminum vibration.
Thanks for any feedback. New to the fireplace insert experience. We had an old (1985) Vermont Castings Resolute in front of the fireplace previously, so am more used to wood stoves than inserts (got rid of it as we have a small living room and my wife didn't like that it stuck much more into the living room.)
Jeff
![[Hearth.com] New Clydesdale 8491 breakin fire and couple of questions [Hearth.com] New Clydesdale 8491 breakin fire and couple of questions](https://www.hearth.com/talk/data/attachments/255/255264-b5bffde16b16f1d884eeec2ed9d04ff9.jpg?hash=JV5eLPbEkQ)
Jeff
![[Hearth.com] New Clydesdale 8491 breakin fire and couple of questions [Hearth.com] New Clydesdale 8491 breakin fire and couple of questions](https://www.hearth.com/talk/data/attachments/255/255381-810789b012c2d56c3345178fcb08aa9a.jpg?hash=7IRlgujNHT)
![[Hearth.com] New Clydesdale 8491 breakin fire and couple of questions [Hearth.com] New Clydesdale 8491 breakin fire and couple of questions](https://www.hearth.com/talk/data/attachments/255/255426-4549a0776aaa7c492b8179be6f267068.jpg?hash=eeKEuAc110)
![[Hearth.com] New Clydesdale 8491 breakin fire and couple of questions [Hearth.com] New Clydesdale 8491 breakin fire and couple of questions](https://www.hearth.com/talk/data/attachments/255/255438-6b5c04193cda6d3ffc1a15e489249b6b.jpg?hash=ziaLyx9mtQ)
