I got a look at my sisters and it has a gap like that too...Would someone be willing to open up their HC and check the position of that standoff?
Gonna toss the SBI dice again, eh?Got a question for you guys with the Heat Commander. I am upgrading from a Heatmax 2 and see that the Heat Commander actually has a spot to hook up an outside air kit. The Heatmax 2 did not, they just said to put one close to the furnace if you wanted but there was no physical connection.
So did you guys hook up an outside air kit? I am just debating if it's worth it or not. Forum search leads to about 50/50 split on having them.
Yeah, long story short, it's a money thing.Gonna toss the SBI dice again, eh?
I did not hook my sisters up to OAK...didn't seem like there was enough air flow there to worry about, but her basement is a lil leaky too, so...would depend on the house I suppose.
I don't have an OAK to the Kuuma, but I do have one to the baro damper...much more air flow there than through the furnace.
The makeup air temp doesn't matter...flue temp will always be the same. The baro just opens up less when its hooked to a cold air source.I'm still leary of hooking my baro to outside air.
I get it...Yeah, long story short, it's a money thing.
The OAK pipe (hose) can run pretty cold when its frigid out...but the only real negative that I know of is that with any basement OAK install (that is below ground level, and the OAK source is above the stove/furnace) is that if you have a reverse draft get started the OAK pipe can actually act as a chimney...so the OAK pipe needs to be pretty well sealed up, and metal (or at least not plastic, or combustible anyways)Also what would the negatives of running one that Im not thinking of?
well now that you say it, yeah i can see how you may get a reverse flow of air in that situation and thats how mine would be. my air source from outside would be 3 to 4 feet higher then my furnace where the air intake is. Well that sucks lol , I wonder if there is any type of one way air flow valve you can get, and if that would workThe OAK pipe (hose) can run pretty cold when its frigid out...but the only real negative that I know of is that with any basement OAK install (that is below ground level, and the OAK source is above the stove/furnace) is that if you have a reverse draft get started the OAK pipe can actually act as a chimney...so the OAK pipe needs to be pretty well sealed up, and metal (or at least not plastic, or combustible anyways)
Do you deal with downdraft issues at all?well now that you say it, yeah i can see how you may get a reverse flow of air in that situation and thats how mine would be. my air source from outside would be 3 to 4 feet higher then my furnace where the air intake is. Well that sucks lol , I wonder if there is any type of one way air flow valve you can get, and if that would work
Yeah I never had an issue where the smoke wants to come down the chimney as opposed to going up it.Do you deal with downdraft issues at all?
I almost never do, so I just used metal pipe and screwed the joints...it works fine.
Plus I think the whole backdraft/ OAK acting as a chimney issue is of more concern with a source of outdoor air (from a higher point than the stove/furnace) that is not direct connected to the stove.
If your house was built recently then I'd install a OAK, if it's and older house that's leaky then I wouldn't. My furnace was in a basement that had a egress door and it was leaky enough that I didn't have to install OAK even though the rim joists etc were spray foamed.Got a question for you guys with the Heat Commander. I am upgrading from a Heatmax 2 and see that the Heat Commander actually has a spot to hook up an outside air kit. The Heatmax 2 did not, they just said to put one close to the furnace if you wanted but there was no physical connection.
No I didn't have any smoke issues.If your house was built recently then I'd install a OAK, if it's and older house that's leaky then I wouldn't. My furnace was in a basement that had a egress door and it was leaky enough that I didn't have to install OAK even though the rim joists etc were spray foamed.
Did you have smoke issues with your Heatmax ? If you didn't have them with your Heatmax then I doubt you'll have them with your HC.
My HC is about 5 feet below my intake for OAK. I'm running solid duct. I had to put in the oak because I have a constant exhaust running to help vent radon and humidity off the basement floor.well now that you say it, yeah i can see how you may get a reverse flow of air in that situation and thats how mine would be. my air source from outside would be 3 to 4 feet higher then my furnace where the air intake is. Well that sucks lol , I wonder if there is any type of one way air flow valve you can get, and if that would work
The other thing to consider is with a tight house you are going to pull gas from your furnace at the end of the burn (especially if running range or bathroom vent). The draft is simply too low at this point and the other vents will win. We had our CO alarms going off at the end of burns the first week until I installed our OAK.My HC is about 5 feet below my intake for OAK. I'm running solid duct. I had to put in the oak because I have a constant exhaust running to help vent radon and humidity off the basement floor.
I have a very leaky home though. You could try putting a gravity/spring damper in the OAK and just don't put the cap on the other side to isolate the OAK. That would let inside air as well as outside. If your house is tight enough I would imagine the gravity damper opening to draw air as needed. Or you could just put a manual damper in the intake line.
Yes I actually didn't mention that, besides my house being pretty tight I have an exhaust fan in the basement that runs all the time as well mostly for humidity, its bad in the summer but I don't have a fire then, in the winter like now the humidity collects bad on the warmer rainy days, and I put a few cord of wood in the basement so it helps to keep that nice and dry besides the basement. I'd bet my basement is probably at a slight negative pressure most of the time so if I put am OAK in, I'm thinking it probably wouldn't exhaust air out of it anyhow as it would probably be always having air pulled in through it , into the basement whether I have a fire going or not.My HC is about 5 feet below my intake for OAK. I'm running solid duct. I had to put in the oak because I have a constant exhaust running to help vent radon and humidity off the basement floor.
How about an ERV or HRV? I installed a Panasonic ERV that pulls fresh air into the house and exhausts stale air outside. I can select 50-100 cfm for both intake and exhaust, which allows me to slightly pressurize the house and make up for exhaust fans, dryer, and chimney flues.Yes I actually didn't mention that, besides my house being pretty tight I have an exhaust fan in the basement that runs all the time as well mostly for humidity, its bad in the summer but I don't have a fire then, in the winter like now the humidity collects bad on the warmer rainy days, and I put a few cord of wood in the basement so it helps to keep that nice and dry besides the basement. I'd bet my basement is probably at a slight negative pressure most of the time so if I put am OAK in, I'm thinking it probably wouldn't exhaust air out of it anyhow as it would probably be always having air pulled in through it , into the basement whether I have a fire going or not.
Sleewok so how did the OAK work out for you in the end, I take it, it works as for what you need it to do, I like the gravity/spring damper idea, that may work, also I have an CO sensor as well, but upstairs, I never had that go off, but I'm going to now move it to the basement and see, like I say i only ever get a very little smoke smell is when its a bit warmer like around freezing or a couple degree warmer,
Thanks for the info everyone
Well there is a great idea, I never knew of those. I will definitely look into those a bit. From what i just seen it looks like the Intelli-Balance® 100 is a whole house system that can regulate incoming and out going CFM , The ERV FV - 04VE1 looks to be the one for a single room like a basement, but from what I see I don't think you can adjust the incoming and outgoing CFM .How about an ERV or HRV? I installed a Panasonic ERV that pulls fresh air into the house and exhausts stale air outside. I can select 50-100 cfm for both intake and exhaust, which allows me to slightly pressurize the house and make up for exhaust fans, dryer, and chimney flues.
ERIC
I have had the Panasonic Intelli-Ballance 100 for about 4-5 years and I run it on 60-70cfm in and 50cfm exhaust. You can also set how many minutes per hour you want it to run. I usually do anywhere from 40-60 per hour.Well there is a great idea, I never knew of those. I will definitely look into those a bit. From what i just seen it looks like the Intelli-Balance® 100 is a whole house system that can regulate incoming and out going CFM , The ERV FV - 04VE1 looks to be the one for a single room like a basement, but from what I see I don't think you can adjust the incoming and outgoing CFM .
What model do you have?
Here was my issue with the whole house air exchanger, it was ok in the summer time, but if your running AC it was taking the cold air out and dumping in warmer/hot humid air, in the winter the opposite, took the warm air out and brought in the cold, also in the winter the issue I had was with the wood furnace, it would bring smoke into the house depending on wind etc. so that unit has been unhooked for quite a few years, I went to the humidity fan in the basement and stuff and that has always worked great, I'm sure my house leaks some, and just with windows open/ doors opening etc I always had plenty air exchange. it wasn't a big issue with my newmac but with this furnace the way the drafts works I think it needs a little more neutral too positive air pressure. The air exchanger I have unhooked though I couldn't change the air flow though It was equal in to equal out I believe.
The Intelli-Balance® 100 is a whole house unit I believe but don't see why I couldn't run it just in my basement i could set it for a little positive pressure, I'd be worried about it having the same issue with it bring in smoke though it, but on the other hand if my furnace has the air it needs and is burning cleaner i may not have a smoke issue.
How does yours balance the incoming and outgoing air temp, does it equalize them pretty good? I would think the newer units are better then my older one.
Thanks for the info about the Panasonic ERV.
Installing the OAK solved my issue with carbon monoxide immediately. With the vent in my basement I have a constant supply of air pulling even when the furnace is not running. It sort of acts like a make-up air supply for my ventilation. ... Anyways, I haven't had a single issue at the end of my burns since installing it. I still get smoke when starting a fire, but that's partly because my wood is not always fully seasoned.Yes I actually didn't mention that, besides my house being pretty tight I have an exhaust fan in the basement that runs all the time as well mostly for humidity, its bad in the summer but I don't have a fire then, in the winter like now the humidity collects bad on the warmer rainy days, and I put a few cord of wood in the basement so it helps to keep that nice and dry besides the basement. I'd bet my basement is probably at a slight negative pressure most of the time so if I put am OAK in, I'm thinking it probably wouldn't exhaust air out of it anyhow as it would probably be always having air pulled in through it , into the basement whether I have a fire going or not.
Thanks sleevwokInstalling the OAK solved my issue with carbon monoxide immediately. With the vent in my basement I have a constant supply of air pulling even when the furnace is not running. It sort of acts like a make-up air supply for my ventilation. ... Anyways, I haven't had a single issue at the end of my burns since installing it. I still get smoke when starting a fire, but that's partly because my wood is not always fully seasoned.
If you are using electric to make hot water I would look into a HPHW. It will dehumidify your basement 365 days a year and save you a ton of money on your electric bill for making hot water.Yes I actually didn't mention that, besides my house being pretty tight I have an exhaust fan in the basement that runs all the time as well mostly for humidity, its bad in the summer but I don't have a fire then, in the winter like now the humidity collects bad on the warmer rainy days, and I put a few cord of wood in the basement so it helps to keep that nice and dry besides the basement. I'd bet my basement is probably at a slight negative pressure most of the time so if I put am OAK in, I'm thinking it probably wouldn't exhaust air out of it anyhow as it would probably be always having air pulled in through it , into the basement whether I have a fire going or not.
I have a direct connection from outside to the furnace. I plan to put in a manual damper to control the air in windy days.Thanks sleevwok
my issue is very similar to yours, the more I look at it I think my immediate fix and cheapest is to run a OAK. Is yours just a straight run from the outside and dropped down to the furnace, or do you have any dampener or anything special done with your.
Is yours connected right to the furnace?
thanks for the info.
