I recently posted I had paint peeling off my zero clearance fireplace due to a failed gasket. I have since fixed both the paint and the gasket. I thought my experience might be helpful to others.
- Getting the old gasket out was awful. Took a combination of chisels, files, and wire brushing and the odd swear word. I then gave the metal a good wipe with acetone.
- SBI makes a great gasket kit with the sealant. I bought it online through Drolet. It was a third of the price RSF wanted to charge and I think it is a better gasket.
- I substituted SBI stove paint in metallic black instead of Stove Bright metallic black – it was a perfect match. I only spot sprayed certain areas – not the entire stove and everything blended in perfectly. I did about 3 light coats about 25 minutes apart – also bought through Drolet.
- Before spraying I sanded areas with 320 and then 600 grit. I wiped everything down with acetone.
- I waited about 4-5 hours before curing the paint with the first and second fires.
- To cure the new paint I did two fires. The first fire was a small fire of about 7-8 pieces of about 1” in diameter – really just a substantial kindling fire that lasted about 30 minutes. The 2nd fire followed immediately after. Using the coals from the first fire I laid 3 pieces about 4” in diameter. I was careful with the air control damper to make sure it was not too roaring of a fire. It lasted about 70 minutes.
- I did not want the new gasket to pull off the new paint that would be curing for the first time. I used aluminum foil to cover the gasket and it worked very well. Do not remove the aluminum foil until the stove has cooled down. I waited until the following morning.
