We're putting a second-story addition on top of the small section of our house that is currently only one story. Since it's on the opposite corner of the house from the Ultima and sometimes the Ultima can get a little overwhelmed even before the addition I figured I'd run a new chimney up at the same time for a second stove. Where the chimney goes up through the addition it needs to be framed in with 2" air space per code. This seems to suggest it will still get hot even through the inch of packed insulation. So here's the question, which came up in another thread recently but didn't get answered: is it worthwhile to put vents in the new internal chase, or even to use some sort of screening rather than drywall for the chase walls, in order to grab some extra heat? I'll need to use double-wall stovepipe because it's going to be a tight corner install (looking at the small Napoleon) so the internal chimney temp will be somewhat higher than with single wall.
Because my office in the addition is going to be up the stairs and through two other rooms I'm not sure even two stoves will heat it enough without some help. So I'm looking into adding in some ducts (with fire dampers! I don't want to restart that fight.) just above the new stove to the office floor. The cold air return in this case will be the stairwell, which already serves that function pretty well for the Ultima. I'm hoping to get enough natural convection to even out the temps, but I can always add a fan if needed.
