New Italian wood pellet stoves either Ducted with Temp of ducted air shown or Hydro, see video on yo
Don2222
9,117
Salem NH
Hello
MCzed video
Interesting, We now have a number for ducted air temperature for a wood pellet stove!!
Vid shows duct work temperature of 80 Degrees C or 176 Degrees F , So the 150 Degrees F I measured in our duct work is completely reasonable!!!
Looks good!
http://www.youtube.com/watch?feature=player_embedded&v=uzR4BOqTZZk
Also looks like a max of 8 meters which is 26.25 feet, our ducting is alot less too !!!
Website
http://www.woodpelletstoves.ie/mcz-heating-collection
See pic 1 of Forced Hot Air wood pellet stove
and See pic 2 of Hydronic wood pellet stove below:
i actually just purchased a mcz pellet stove (wittus EGO but its not ductable)
Hi CrowBean
How do you like the EGO?? How large is the Hopper??
http://www.wittus.com/DProducts/wpdopellet.htm
The Ego and Star's innovative Active System instantly adjusts the combustion air to compensate for minor variations in pellet size and density. The stove determines the perfect amount of air to obtain the best possible combustion in any installation configuration.
The top mounted user-friendly LCD display control panel monitors the internal functions and provides valuable information to keep your stove running at peak performance. No doubt about it, this is a smart system!
Other features include:
pre-programmed user selections
optional remote control
self-cleaning burner box
easily removable ash drawer
large hopper capacity
gentle flame patterns for enjoyable viewing
quiet operation to give you a stove that is a joy to own and operate.
Hello
These 3 below are ductable with 60 lb hopper. I wish they had a bigger hopper!
Copy and paste URL to make it work
http://www.wittus.com/catalogs/pellet flyer web.pdf
Manual
http://www.wittus.com/Specs/pellet-S-C-M_Air-Comfort air_Rev4.pdf
Smart Pellet Stoves with Deluxe Comfort Air®
The Club, Suite, and Musa models come with Active Air
or Multiair, which includes Comfort Air®. The patented
Comfort Air® system works in concert with the Active
Air system to provide yet another level of smart heating.
These duct-able stoves allow you to duct heat through
walls to rooms up to 25’ away.
Comfort Air® extracts the heat produced by the stove
with unequalled efficiency. Its unique two-fan system
allows you to independently adjust the heat output to the
room and to the rear duct system. It is quiet in operation,
and does not require maintenance.
The user-friendly remote control has just
a few buttons to control the versatile
timer that is already pre-set with 60
daily and 10 weekly programs.
The Club (shown above) is available with heat retaining
ceramic panels in bordeaux, white, or sand.
The Suite (shown on back cover at the top) comes in
architectural ceramic in bordeaux, pepper white, or
mustard.
The Musa (shown on back cover at the bottom) slender
and understated, comes with steel side panels in
bordeaux, white, black, or silver (same as the Ego on
the opposite page).
Club and Suite (C) and Musa (M) Specifications
Heat Output: Dimensions:
Maximum 12 kW - 40 kBTU (C) Height 115 cm - 45 in
Peak Efficiency 94 % Width 58 cm - 23 in
Capacity - up to 185 m² - 2000 ft² Depth 56 cm - 22 in
Hopper capacity 44 ltr - 60 lb Back Vent ht 44 cm - 17 in
Weight 160 kg - 350 lb Outside Air ht 26 cm - 10 in
Pipe diameter 8 cm - 3 in (M) Height 109 cm - 43 in
Outside Air diam 5 cm - 2 in Width 50 cm - 20 in
Duct Air diam 5 cm - 2 in Depth 56 cm - 22 in
(C) Duct Air ht 101 cm - 40 in Back Vent ht 38 cm - 15 in
(M) Duct Air ht 95 cm - 37 in Outside Air ht 20 cm - 8 in
Club
The EGO is being installed in 3 weeks after i build the hearth out of stone. I will definitely update you now that i am addicted to this forum and pellets! The ductable units are very nice but i end up getting the ego, install, tax, ash vac, 2 cleanings for 4000. The ductable units start at 4500. Alittle too out of my price range after install and other goodies but a great design. I am very excited about the features and the possible 90 percent efficiency.
Sounds like a very nice unit! Does it use US standard 3" pellet flue pipe?
I am interested in the ducting because we had a heated debate about it. :)
Ducting is not against the current codes but having a flange like these stoves have make it more acceptable. :)
See debate
https://www.hearth.com/econtent/index.php/forums/viewthread/76419/
From Manual
CONNECTIONS OF HOT AIR DUCTS FOR
SUITE/CLUB/MUSA COMFORT AIR MODEL
Once the stove is in position, you can begin installation of the hot air
ducts.
Comfort Air stoves are provided with an air deflector E as standard. This
means that the rear flange for hot air outlet is connected to this
deflector, which allows the hot air to be directed to the right and left of
the room, in case the channelling of hot air is not desired.
If you wish to channel the hot air, the deflector E must be removed.
Connect the soundproofed connection F (optional) that makes the
output from square to round 3â€, and then make the various connections
through the wall using only “type B†vents. To transport hot air inside a
wall use the proper “type B†oval ducts suitable to be walled in (see
connecting examples in the figures on the right)
The air outlet heating air can reach very high
temperatures, up to 180°C: it is therefore necessary
to use “type B†vents where it may come into contact
with flammable surfaces or that are affected by the
temperature (e.g. discolouration of paint, ducts for
electric cables, plasterboard, etc.); it is also
necessary to protect people and animals from
voluntary or accidental contact. In any case comply
with the regulations and laws in force in the region
where the product is installed.
It is advisable to provide insulation along the entire
route of the pipe to decrease dispersion and increase
the heat energy in the environment.
A pipe which is inserted in the wall must be properly insulated so that it
does not lose heat and so that air outlet is silent.
8 meters is the maximum suggested length for
ducting hot air in other ambients.
The recirculation of air in the room occurs using the perforated sheet
metal placed in the rear of the stove C and the holes placed on the
metal sheet bottom
It is possible to choose the volume of air you wish to discharge from the
front part and from the rear part of the stove in an independent
manner, by adjusting the ventilation power directly with the remote
control.
Hello Crowbean
You should really get the service manual for your stove. It can be really valuable for maintenance!
You can download it here but you need to ask your dealer for the password!!
Copy and paste this entire URL to your browser for it to work!!
http://www.wittus.com/Specs/Pellet service manual-10.pdf
yes according my dealer its a 3" venting pipe and im not using the OAK
Why not the Oak? I ask because I'll be putting a piazzetta in next month and I'm deciding on how to go about the install.
