I purchased a Lopi Answer Nextgen insert in October & had it professionally installed complete with stainless steel stovepipe. It is rated to heat up to 1200 sq feet with EPA tested BTUs of 12,129 to 59,527 and an overall efficiency of 72.4%. I have used it approximately 30 times since purchasing it and have been unable to raise the ambient temperature from 69 degrees to past 71 degrees in the approximately 400 sq foot interior room where it is located. The thermometer I am using is approximately 10 feet from the stove at 3 feet off the floor. I have tested it and it is accurate. I set my fire using wood at 13-14% humidity measured with a moisture meter provided with the stove. I fill the box half full and get the first strongly burning (damper full open) and then load it and get the remainder fully engaged before closing the damper 3/4 with the temperature on the door at about 400 to 450 degrees (measured with infrared thermometer). I have also tried keeping the fire box full, damper fully open with a raging fire. I have a built-in fan on the stove that comes on when it reaches 135 degrees and I put this on full. My dealer sent the installer back out to re-check the installation and he said it is fine. The dealer came out and personally tested the wood moisture (13%) and the methodology I used to set my fire. The temperature outside was about 41 degrees and the stove brought the temperature in my room from 69 to 71 in about 1 1/2 hours-no higher. He said I was used to a bigger stove and intimated I was expecting too much. His solution is to sell me a larger Lopi insert. For 41 years I used an old Craft Stove insert that raised the temperature in the same room to 80 degrees if I got the fire too hot. This is an interior room with a floored attic (insulated) above and insulation in the floor below. The exterior windows in the surrounding rooms are all Anderson double-paned, likewise insulated. The house itself is all brick, well-insulated.
My question: am I expecting too much of this insert to raise the temperature to about 75 degrees in a 400 sq foot room? Am I using the insert properly? Any reasonable suggestions appreciated!
