Hello all, not sure if posting in right forum, any help or advice is appreciated,  I purchased and had installed osburn 1700 insert about 3 weeks , after using twice the fiberglass gasket stuck to stove and about 5 inches came off bottom, I called the store that sold and installed it and was given a tube of cement to re adhere it, which I did , 3 more fires later and the door handle was a little stiff opening when I went to clean it out ,after cleaning ,the door will not close, the problem is not the handle ,it won't get close enough to engage the handle,I can force it closed probably but don't want to push the insert, looking into stove as I'm closing it ,it looks like it does not have room to close on side where the hinges are ,the hinges look ok , there is no play.
I took a level to every part of stove I could and there is no warping or damage, I did not overheat the stove as well ,the gasket in hinges area of door is touching the stove face when I attempt to close door not sure if gasket can swell being it was brand new , the hinge area is not where it was re attached either that was is middle of stove door where the end of gasket is placed and the door does not close to that point, I have not really found any bad reviews on the Osburn 1700 insert, unless I just got a lemon.
I called the store 7 days ago left voice-mail waited 2 days after not hearing back and called and spoke to person who said would relay the message to my salesman I again waited 3 days after not hearing back and called yesterday and was advised the salesman said he is aware of my problem and I'm on his "to-do" list, well still no contact, I'm not able to get to store personally after having surgery and not being able to drive for several weeks still ,not sure if this is an easy fix or if I should return the stove altogether, the store has 30 day return policy with me losing 15% if I return, I'd rather eat the 15% if the osburn is not a good stove and go elsewhere for stove and another brand, any advise would be appreciated
		![[Hearth.com] New Osburn 1700 insert  door problems [Hearth.com] New Osburn 1700 insert  door problems](https://www.hearth.com/talk/data/attachments/300/300549-06bba9da688e3824dc421dc142b1782f.jpg?hash=YP2s39VLyR)
![[Hearth.com] New Osburn 1700 insert  door problems [Hearth.com] New Osburn 1700 insert  door problems](https://www.hearth.com/talk/data/attachments/300/300550-debae61c855dd21ab79967ff1adcbace.jpg?hash=oU1A_Px7xl)
![[Hearth.com] New Osburn 1700 insert  door problems [Hearth.com] New Osburn 1700 insert  door problems](https://www.hearth.com/talk/data/attachments/300/300551-cbab8a25fe7c8a9f6a88fd8cbea8ff87.jpg?hash=nDk-mS_qXN)
![[Hearth.com] New Osburn 1700 insert  door problems [Hearth.com] New Osburn 1700 insert  door problems](https://www.hearth.com/talk/data/attachments/300/300552-18e21a34794479c9cb7fe1f48608ac83.jpg?hash=e3sC9pcSx8)
![[Hearth.com] New Osburn 1700 insert  door problems [Hearth.com] New Osburn 1700 insert  door problems](https://www.hearth.com/talk/data/attachments/300/300553-75b234c9893afe0144791d7cc2833645.jpg?hash=ez8Yv6D_O1)
![[Hearth.com] New Osburn 1700 insert  door problems [Hearth.com] New Osburn 1700 insert  door problems](https://www.hearth.com/talk/data/attachments/300/300554-677abe9eb41d12af63b9b26dbb4fae2a.jpg?hash=qL8NkxYnWn)
![[Hearth.com] New Osburn 1700 insert  door problems [Hearth.com] New Osburn 1700 insert  door problems](https://www.hearth.com/talk/data/attachments/300/300593-12ecc1370c95089e14576359936a1b6c.jpg?hash=HBmcZblggz)
![[Hearth.com] New Osburn 1700 insert  door problems [Hearth.com] New Osburn 1700 insert  door problems](https://www.hearth.com/talk/data/attachments/300/300594-2e872942fcd7be8ac155852208a07723.jpg?hash=EAlJLLHEzS)
![[Hearth.com] New Osburn 1700 insert  door problems [Hearth.com] New Osburn 1700 insert  door problems](https://www.hearth.com/talk/data/attachments/300/300595-ddac1d48daedb8654e32f4b20aa01748.jpg?hash=MdnioXGZFW)
![[Hearth.com] New Osburn 1700 insert  door problems [Hearth.com] New Osburn 1700 insert  door problems](https://www.hearth.com/talk/data/attachments/300/300596-23936b43915f4c2a76b34b4519d1a8ec.jpg?hash=edirUack7F)
![[Hearth.com] New Osburn 1700 insert  door problems [Hearth.com] New Osburn 1700 insert  door problems](https://www.hearth.com/talk/data/attachments/300/300619-ec52fdd3f6591d651d39b2d6c5f172d7.jpg?hash=U4iFjKOymF)
