We just replaced a troublesome wood stove with a Hudson River Chatham model, which we have been running the past two or three weeks. It does a good job of heating the area where it is (the family room), and a fair amount of heat climbs the stairs to the bedrooms. The house is well-enough insulated that I've been keeping the stove on its lowest setting, and the room temperature is still in the high seventies.
A couple of newbie questions, if you don't mind: First, there is a lot of soot buildup inside. It vacuums off very easily, even off the glass in the door, but I'm wondering if the blower setting and the damper might need tweaking, or if this has to do more with pellet quality (the quantity of soot seems to vary from bag to bag; we are burning Okanagan Douglas fir pellets).The user manual seems to say that soot build-up means the fire needs more air, but even though I've read the manual several times, I'm not really clear how on to tell if the flame is right. The manual calls for "a bright yellow/orange, active flame with no black tips," but as far as I can tell, that's what I'm getting, regardless of the position of the damper. The only noticeable difference is that fire does seem to get taller when the damper is all the way in and shorter when it's pulled out. Should the flames be reaching as high as the top of the firebox, or is that too much? Should I adjust the damper when the stove has been feeding the fire pellets to build it up, or wait until one of the more subdued periods? Since I am running the stove on the lowest temperature setting, I did bump the combustion blower up a notch, as the manual seems to advise.
Second is the the air intake. The installers left the stove drawing air from the room. The house is fairly open-plan, so this does not seem to be a problem, but what do I know? How crucial is it to be drawing outside air? The stove is positioned against a chimney that was apparently designed to accommodate the wood stove when the family room was added on, so apart from getting through the granite facing, it shouldn't be hard to install an OAK (if that's the right acronym).
Lastly, is there any real problem with turning the stove off and on? The dealer said something about burning out the ignitor more quickly if we did that. Now ignitors seem to be fairly expensive if you buy them from Hudson River, but several Web sites offer them for about a third of the price. Is this one of those things where one buys the cheapest, or where one gets what one pays for?
I have to say, I've been exploring this site, and have found a great deal of useful information already. You guys seem to know your stuff!
