We bought a home in Cherry Log, GA about a year ago, working on selling 12 acres a kennel and the prior home.
The new house is about 2800 sq’, two stories and a basement. There is a large garage with a 900 sq’ “Carriage House over it too.
A large amount of big roundish, river rock was used in the cnstruction of the house. One end of the basement floor is made entirely of river rock. Climbing the three stories, counting the basement, of the house is a large chase/chimney. The outside of this chimney is around 8’ long x 2-3’ thick. The ground floor of the house has a large 87-89” wide x 16’ tall section that is the inside portion of the chimney. As in many mountain homes there is an opening for the living room that goes up into the third story. The inside portion protrudes 6-12 inches into the house, and has a large solid granite slab protruding from it. The hearth is curved, about 13” from the river rock on each edge, and about 20” in the middle. There is currently a wood burning fireplace and blower in the 43” wide x 37” tall opening in the river rock.
Below the main floor, in the basement, there is a double closet framed in below the chimney & hearth above. The entire top surface of the chimney is made of river rock, other than the small round, covered flu.
I started out looking at inserts that would fit into the existing fireplace. The units we liked do not fit in the existing opening. One company we have talked to says that their insurance provider is threatening to cancel coverage if they cut out parts of existing units to fit new ones in. Apparently they use to regularly remove/modify parts to get new ones to fit.
It seems to me that there should be a way to remove the entire old unit, insulate the space better, and seal it against weather and heat better. I would hate to modify the existing wall and structure, but wonder if modifying the existing space might give me the extra room I need?
