Two Harmans aren't enough??Now I am on the fence about one but it would likely be the ideal smaller BTU stove I would want
They heat what they are intended for well. The P68 does the two levels and main core (2,350 SQ FT) of my house that we mainly use very well. The PC45 is in a large 14 ft. high ceiling 1,200 SQ FT open room. Big family room that I added in 2005 and also covers a corridor and area off of that. I want a smaller stove for another area that is not used a lot and / or an additional supplemental heat source.Two Harmans aren't enough??![]()
It is nice to have a bunch of space but sucks maintaining and heating and cooling it but I am all in one spot. Wife and I are definitely going to down size as soon as she retires in 7-8 years and the kids have flown the coup.
Any new review on Greene team platinum pellets? Thanks
Castle serenity pellet stove feed rate "kind of" figured out. Max heat on low settings.
Set stove to manual.
Set to lowest setting - 1 "first bar" (lowers fed rate)
Set blower voltage- Stall 1 to 100/105.
Set exhaust voltage - stall 1 to 90.
Air intake at half.
Stall 1 because we are on low that is stall 1.
Burning GREEN TEAM PLATINUM. Review ****
Better than the cheaper pellets. 1 dollar more a bag at Lowes but worth it. GTP-$6.29 / store brand $5.19
With these settings the serenity stove burns very low, and minimal dirty glass! Max Heat for low.
Uses less pellets and works good for me. I would recommend this for fall weather when it gets colder I will update post with new settings then.
Have you made any other changes in the stall setting for the blower or exhaust , thanks in advance !!
Has anything changed, or do you find this is the normal behavior of the flame? Just installed mine and it behaves the same way..I'm sorry to raise an old thread from the dead but didn't see anything newer to comment on. I just bought my Serenity maybe a month ago and have used it a few times. I am new to pellet stoves and wondering if it's normal for the flame to be really high when first starting and then go down maybe a few inches above the pot? Seems to go on a cycle where the flame will dip down below the pot and eventually above and then high again. It has never overheated or thrown any faults but I worry when it really begins to get cold here in upstate NY and I need to use stall 2 or 3, it'll overheat.
I have only ever ran it in manual mode stall 1. I did however change my voltages based on some posts I've found here.
Blower Voltage: 95, 100, 105, 110, and 115v. Exhaust Voltage: 90, 95, 100, 100, 105v. Air intake is set at half from factory.
Thanks. What do you burn? I bought 2 ton of TSC I have nothing to compare them to as this is my first PS. I hear that soot buildup is typical as well? What is your experience with soot on the window?Normal: auger cycle on low dumps pellets burns high
auger off pellets burn down. the auger comes on dumps pellets
cycle starts again. Normal with stove set on low
