new stove
On the advice of my liability insurance carrier I am staying out of this thread.
Reactions: Owen1508
This has gone far beyond post #7 "All I want to cut out is enough to slip the liner in and the slanted area in the back..." At post #11 it was possible to recommend an insert. Now, I don't think so, but will let others add their thoughts. From what I can see, it looks like you can still put in a freestanding stove with a full stainless liner, but I'm concerned about what's holding up the brickwork without the form in place.
I am not trying to cut corners I want to fix it right Im just having a hard time finding requirements
Check with your local building code inspector and the company whose stove you want to install. A certified sweep from your area may also be able to give some advice: http://www.csia.org/search
I would think about putting a stove in there as an alcove installation provided all walls are non-combustible:
(broken image removed)
I doubt an insert would still be permissible in your situation. A stove should be cheaper, too.
Fair point I am replacing the sill where the brick rested before and tying everything back together so structurally I don't see any concern with anything falling out
