We just purchased a house in Eastern Tennessee. There is what I think is a Grandfather Fisher stove in the downstairs family room.  After the season, I think I need/want to replace the stove pipe from the stove to the chimney, the former owner has the pipe going into the stove connection rather than round the stove connection.
Chimney was inspected and was said to be in good condition. I have seasoned fire wood. We can get decent fires going, but not what I'd call a roaring fire. My problem is that even after hours of having a fire going there isn't a whole lot of heat coming from the stove. A stove that size should be able to heat most of my house, and it doesn't even make the one room it's in very hot.
From this forum, I think I will look to add a damper inside the stove. There is the small round damper in the stove pipe. If I close that damper even a little with the doors open, I get a ton of smoke in the room.
Is the stove meant to be used with the doors closed? With no internal damper, and the pipe damper open, is alot of the heat going up the chimney? I've owned a lot of wood stoves, and never had this problem.
PS: I've spent a day ready all the posts. I've learned alot (maybe more than I knew could be learned).
Roger
Roger
		 Good you found it before it got cooking in there.
