Hello, first post here.
I have a new to me Keystone that I'm learning to run and have a couple questions. A bit about the stove:
-It's a 2011
-Just replaced the combustor and it's gasket
-Unfortunately after getting it home I noticed that there was some warping of the bypass cover and combustor pan. I've been in contact with Woodstock and Jeff Gibbs (former builder for Woodstock), and have replaced the bypass cover, it's gasket, and now get a good seal with the cover. The combustor pan will likely get replaced next summer.
-I've only been running the stove about a week now so I'm still in the learning curve.
So far I'm getting pretty good burn times and the combustor seems to be working quite well. White smoke or no smoke from the chimney, rising temps after engaging the CAT, and visible glow at times. I usually load the stove twice a day, once before bed and once before I leave for work in the morning, sometimes more on the weekend. I've been noticing that if I let it die down all the way, stove temp maybe 100-150 and very little coals left that the inside of the stove, primarily the back lower corners and near the door have some shiny black creosote. Is this normal? Is there anything I can do to prevent it?
The stove is set-up top-venting, near straight to a 45 degree turn through the wall, then 90 degrees straight to the top. Straight vertical run is maybe 25' so I feel I have good draft. I checked the chimney tonight and it appears pretty clean, just a bit dusty, no shiny creosote anyway.
Lastly, I'm a fairly experienced wood burner but never used a catalytic stove before. Always had a wood stove growing up and in this house for the past 3 years we've run a VC Encore 1450 non-cat.
Any input, tips, or advice is greatly appreciated!
-It's a 2011
