Hi!
I bought a house beginning of this summer (my first one yay!) and it has a wood stove.
Here's the model
Drolet Myriad ((broken link removed to http://drolet.ca/en/products/wood/myriad))
I've cleaned my chimney 1 month ago before the cold started to arrive. I've already made a couple of fires and so far, it is not great, but it is not bad.
The issue I have, is when reloading, it takes a long time to catch fire (only small flames) so it produces a lot of smoke for quite some time. When I start a new fire, everything goes great, everything catches fire rapidly (even a huge log placed on top of kindlings, the draft seems perfect, etc...). So since big logs catches fire rapidly when starting a fire and my draft seems good (I can get an inferno in the stove easily when starting a fire), I think it is more a user issue than a draft/seasoned wood issue
On the website for my stove, it says it is a reload over depth type. Is this what I see on the internet called "front to end" ? Because most diagrams I saw for front to end seems to have the intake right trought the door, but mines uses a pipe in the upper front with the intake behind the stove (you can see the diagram by clicking on download the brochure).
If it is, I saw that I should move the red ambers up front real near the door and then place logs. But how exactly?
Should I make a pile of ambers and place logs with the end facong the door on top of the ambers and the other end at the back on the bottom of the stove? And then pile up multiple logs if I want to burn more than one log? Or should I simply put the whole log at the bottom and simply make them touch the ambers? And if I want to put more than one log, should I stack them in opposite directions (3 logs on the bottom going front-end, 3 logs on top going side-side) or all logs in the same direction all stacked tightly like when you pile up wood?
Thanks for your inputs and if I have a warm winter, it will be in part because of what I read here before starting
Here's the model
