Let me first apologize since I'm convinced the info is here but I cannot find.
Basic scenario is we have some property with a small home and would like to use a pellet stove. Total area < 1000 sq ft. This house is old and poorly insulated (mobile home with an addition) and is temporary, we will eventually (3-5 years) build a new house there.
We only spend some weekends at the property and have a heat pump to maintain a minimum temp of 50 while we are gone. The heat pump is pretty useless at truly heating the home but we're gone too long for the pellet stove to be primary and my wife would never go for flames while away.
Once we build a new house we will likely go to a furnace and the pellet stove will move to my future 800 sq ft workshop.
So the questions:
Is there a rule of thumb for BTU/sq ft?
We are in north Georgia and there are very few retail outlets for pellet stoves. The places I have found only have one or 2 models and are asking MSRP. Is MSRP the norm or inflated? Are there good online sales companies?Are there any good sales outlets in the Gainesville, GA area?
Kind of in line with last question, it seems from what I've read the models sold by Tractor Supply, Lowes, Home Depot, etc. are considered inferior units? Am I interpreting this correctly?
Is there any advantage (deals) for buying now in the middle of summer?
I'm sure I'll think of more but thank you for your patience.
So the questions:
What stoves have you looked at and/or researched? Do you have any friends or family that have pellet stoves? They do require regular maintenance of ash removal, burn pot cleaning that are in relation to how much you burn. Venting and internal smoke pathways are usually cleaned after every ton burned.
. Northern GA is a good location for heat pump heating with a modern system that has a high HSPF. A good mini-split from Mitsubishi, Fujitsu or Daikin is super efficient and often will cost less to run than other fuels.
