Newbie needing Ashley C92 manual
gregd66
3
Alabama
Hi, I just inherited an Ashley C92 wood heater. It's supposedly only a couple of years old. The manual wasn't with it, and I'm having no luck with google search. Any idea where the manual can be found? Thanks!
This isn't the manual, but it seems to have some info:
(broken link removed)
Thanks, I did find that site. Mostly parts but good for info! From what I've found out out, it's a catalytic type stove. What exactly is being catalyzed? Also it has a bypass door at the exhaust exit. Does this bypass the catalyst?
I'll try and answer since I'm here, hopefully somebody with more knowledge will come along.
A catalyst in a stove is similar to the catalytic converter in your car in that it has materials in it that when hot, burn off pollutants. In our cases, the catalyst burns off smoke, and actually creates more heat. When you say "bypass", I immediately think of my blaze king, and the bypass does exactly what you say. However, I am not familiar with the stove so I don't know any specifics.
Depending on how old and heavily used the stove was, you may need to replace the catalyst to get any good heat out of it.
That's what I was thinking about the cat. It sits between the firebox and pipe outlet? And the bypass diverts past the cat?
