New to posting, however I am been lurking around this board for the last 6 months or so.
Just have a couple of questions, I purchased a Timer Ridge 55-TRP22 stove from AMFM a few days ago.
I am getting ready to purchase the pipe to install this stove in front of my existing masonary fire place.
My flue is brick / block lined about halfway up, then it turns to clay tiles the rest of the way up, total length of the flue is about 12 feet, and it has a diameter of 11 in x 11 in.
So my plan is to run a solid pipe out of the back of the stove, put a clean out T and then go up from there. What type of pipe should I use to go up with? Flex or Rigid? Should I insulate the pipe? Do you have any recommendations on where to purchase this pipe? There aren't many local options around my area.
I will be removing the dampener and closing off the hole in the flue with a piece of fiber board. Should I insulate above this board?
Thanks for your help.
