Newbie to pellet stoves
tammysteve1971
3
nys
Just bought a used Quadra fire 1200cb . Can you use it without a thermostat and does the front door come off
Sent from my SM-S820L using Tapatalk
Hi Tammysteve- the thermostat is normally the on/off switch for quads. The stove knows you are calling for heat or not. You can put a switch in its place on back of the stove at the stat connections if you want, or just put the stat up all the way and it will run manually. Open the right side panel door (as you look at the stove), the door clips are behind that. Hope this helps.
Yes thats the tstat block. Two center screws are where tstat hooks up to. You can find owners manual at quadrafire.com under pellet stoves.
