Hi
This fall we purchased a Regency I2400 wood stove insert for our fireplace. I am in love with this thing! I have a fire going nearly everyday (along with a new humidifier), and love the process from start to finish. I feel it has helped make our house a home.
My question is kind of a nuts and bolts question about the stove, we couldn't get a great answer from our installer (or maybe we just didn't get it) and it doesn't seemed to be adequately diagrammed in the Regency manual.
Here's my newby take: I think I understand the stove is constructed as basically a 2 layer (or jacketed) box. The chimney pipe goes through both layers into the burning chamber, the combustion air is pulled in from the vents along the bottom and sides into the burning chamber, and the heated air is pushed out (mostly with the fan, but some convection) through a vent slot along the top. This heated air comes from the air warmed around the "outer box" of the stove, not the burning chamber.
If this is correct, here are my questions. Where are the openings inside the burning chamber that allow the combustion air to enter? I'm assuming I want to keep those free of ash buildup. My husband and I have looked around and felt around a bit inside around the firebricks, but can't feel and obvious slot. So we just keep the ash back a bit from the door.
Secondly, when we had our fireplace, it burned poorly, and we had a small vent to outside air knocked in the back of the fireplace. It has a little metal louver cover on it, with a sliding door and allowed another source of outside air. Our insert installer said that we could leave that vent open and that it would add to the combustion air of our insert. But there isn't a pipe or anything leading from that vent into the burn chamber, so it seems to me that the outside air is just circulating around the outside jacket taking away some warm air that could be going into my house. Is there a way or a hole that allows that air into the burn chamber, or should we shut that vent?
This is a great forum, and I lurked here for a bit when we were thinking wood stove vs pellet stove. We are so happy with our decision, and thank you for that. Sorry my first post is so long and wordy, I'm sure there is an easier way to ask my questions, but I'm still learning.
Thanks in advance for any light you can shed...
