Can someone point me to the scientific test and results that NFPA conducts on uninsulated chimney flues. I am a member of NFPA and get daily emails as well as snail mail ,but must have missed the part about chimney flue scientific testing.
Link to source thread pleaseAgain just trying to get a clear understanding the circumstance that would cause such an inprobable thing to happen. I would think its near impossible.
Quick google search found this: Thermal Performance of Masonry Chimneys and Fireplaces.
http://fire.nist.gov/bfrlpubs/fire87/PDF/f87007.pdf
Has quite a bit of info, and I'm sure there plenty more online. Also try googling "pyrolysis" and "chimney" together.
I am looking specifically for the testing data where a liner inside terracotta inside concrete block was able to ignite wood placed against the block.
(broken link removed to https://www.doctorfire.com/low_temp_wood1.pdf)
No doubt but still a worthwhile topic for discussion IMO. When attempting to apply the data collected in the linked study to any given install it would be critical to know at what height and for how long temps above the maximum recommended temp were present on the outer brick surface of the chimney. With that you might make some educated guesses regarding the real world potential for pyrolysis when assessing an individual install assuming improper clearances (i.e. combustible in contact) since that cannot easily be assessed once the walls are closed up.Pyrolysis is serious business. It's like hidden a time bomb in the structure of the house. No one can say how long it will take before ignition will happen. It's better to invest a little up front on the side of caution and safety than to wait for later results.
I would like to know why, if this has been code for so long, are there so many chimneys in so many houses done blatantly wrong yet they where all inspected and signed off on when built......
I can believe this to some extent but I have heard it said here before that something like 95% of masonry chimneys have inadequate clearances. Surely that number is a bit high to be "slipping through the cracks". I know my chimneys do not have the clearance and never have, the house is as built in the early 50s. I also have a friend with a house built in the 80's, I helped him do new siding and his chimney has no clearance either and he told me I was insane when I said there should be clearance. It just seems crazy that this problem is so rampant yet it seems nobody knows or cares outside of these forums.Nature of the beast I suppose. The same could be said for a lot of dangerously done, not to code construction work that is covered by existing building codes. Tons of poorly trained workers and inspectors out there, not to mention homeowner remodeling. A lot of people complain about gov't building codes but I always figured they were useful in making sure contractors were held to some minimum standard.
Mine either. I can see brick in my attic through an old electric box hole in the siding. Must have been for an outside light that was covered over when they put the chimney in. The brick is right up on the siding. I have shot it with an IR thermometer and its cold but I have no doubt the entire chimney above the first floor ceiling is in direct contact with the tar paper covering the tongue and groove siding.I know my chimneys do not have the clearance and never have
