You wont have much if any. There just isnt enough temperature differentialYes im from Canada. I just want to test the draft because i just sweep the chiminey.
You still have a temperature differential between inside and out. That creates a pressure differential and therefore draft. There are times an oak can cool a stove enough that it make it harder to start. But when its cold out it is fairly easy to get enough heat to get it started. When its warm out it is much harder.I liked the above post because it is a witty answer and I'd agree, but how does one explain that theory in relation to a stove with a fresh air intake?
unless it was SUPER bad and clogged. then it will be better than last yearNo need to test the draft after a cleaning. It'll be the same as last winter.
Would putting a small space heater inside the stove for a few minutes get the whole works up to temp?
Yes but even once you get a draft established with higher outside temps the draft will not be that great.For a few minutes, no. For long enough to warm the entire chimney, yeah, should work.
