I live in the foothills of the Oregon Coast Range, get 6-8" snow most years, and get slammed by freezing east winds coming out of the Columbia Gorge. My propane heat has gone out three times in the last four winters, so I need a back-up. Several years ago I tried a flush insert in my relatively large fireplace (40w x 33h opening) but it was mostly worthless for that and I removed it. So, right now the fireplace is open, providing little heat even with a top and sides blowers (open 2'x2' flue!). Last year the heat was out because the propane connector froze; no power problem, but with the fireplace blowers and two electric heaters, the room was barely 50 degrees. Usually I lose heat, though, because the power lines are down, so no blower or electric heater options. I have glass doors on the fireplace now to keep the room heat from flying up the flue, but that's just an interim solution.
I have a ~1000 sq ft great room (avg ceiling height 15'), and think a large (2.4-3.0 cu ft) non-flush insert would work for me. Very confusing on the different attributes, though. With the help of previous forum postings and my contractor, I've narrowed it down to three: Montlake 300, Quasi-fire 5100, and Hearthstone Clydesdale. Because of my room layout, I need an insert with the door handle on the right, and these three meet that requirement.
Based on my primary objective -- continuous heat at some level for at least a couple of days when my furnace is down -- I think the soapstone-lined Clydesdale might be my best choice, although I've been reading in this forum about the cat. conv. issues and don't get a warm and fuzzy from that. My second objective -- a nice fire in the evening -- leans me to the Quasi-fire with it's side windows. The Montlake is on the list because it's most readily available from my contractor, I like the look of it best and the mantel is the deepest (it may work for hot water or soup if needed). A lesser objective is lowering my propane usage, although it's quite low now as it is, and I think any of these would work for that.
Any help to narrow this down for me, please? I've been feeling there must be something that I'm missing that will at least knock one of these out of contention based on my objectives. Thanks.
