I discovered an oops today... I was sort of afraid that I might, and I was right! :shut: We have a pipe that goes from the cold water line in the laundry room out through the garage to feed an outside faucet next to the garage door, and another faucet on our front porch. It has frozen on us before, so I'm careful to shut the line off and drain it in the fall - not a big deal... However the shutoff is a ball valve next to the drier, and during the winter I was fixing the drier and accidentally bumped the valve on, refilling the pipe.... It didn't want to blow out when I realized what happened, so I was afraid it had frozen, but didn't worry about it at the time - can't do much in the winter...
This afternoon I turned the line on, and sure enough it was frozen and cracked in at least one or two places (I found one split, and there was a damp spot that suggested a second...)
Currently the line is copper, I think 1/2" and sweated fittings. I haven't done much copper plumbing, but I've done some other copper sweating work, so I don't see much problem there.
1. Is copper the best thing to replace this with? Or is there a better material I should look at? Probably I'm just going to want to replace the part where the break is, though I could be persuaded to replace the entire run. The run does go around some corners.
2. Any reason not to recover and re-use the elbows and other connectors on the pipes?
3. Given that this is the middle of a run, should I dry-assemble all the joints first, and solder, or try to build each joint one at a time? My current plan is to take the existing plumbing apart, then cut new pipe to match the lengths of the old peices and then put it back together - is this a good approach?
4. Any other "gotcha's" I need to watch out for?
Gooserider
Gooserider
