Warning: I'm green (but eager). O.k., I've read a bunch of posts on this forum. They have really helped. However, I don't have a visual of the right way to burn in my head. I am armed with a moisture meter (I saw a photo of one on this forum somewhere that was purchased at Lowe's. I bought that one. Seems to work great). Likewise, I am armed with an IR gun (again, used a recommendation from this forum. Seems to work great). I learned that I need to warm my wood inside and then split it, again, to get a good moisture reading. Have done that. So, I have some pine (very light and hollow sounding when banged together). Moisture reading is around 13 - 15% or so. I started a fire last night with some kindling. Got it going pretty well with the door slightly ajar and air fully open (by the way I have a Clydesdale Insert). Then, made a strategic decision to put my pine on the fire. Good flames, no smoldering. Let that go on fully open air for a while (with door ajar). Then closed door. Let it go further on open air. Then, started to slowly close down the air. Broke out the IR gun at different times over the night (after loading more pine, etc.) and never saw a reading above about 195 degrees on my insert. I tested the upper left hand corner of the door (above the handle), the middle of the door (top) and other places. Shot the IR into the fire and saw around 300 degrees (I understand that may be misleading because of reflection through the glass, etc.). So.....where's the heat? Could it be my wood is green, like me? Could it be a personal thing between me and my stove? Could it be my wife's fault (I always throw that in).
