You're right. The opening is 50 sq inches. I'm thinking about getting this adapter I like how it comes off at a 45 degree angle, much easier to connect to the liner.What are the dimensions on that hole?
An 8" flue is 50 sq inches, and I'm guessing that is about what that hole measures too.
You have the chimney adapter to go on there?
The radiant heat from the stove will be strong. Is there a wood mantel on the fireplace or close side walls? Also, the hearth will need an extension that protects the floor out at least 16" in front of the stove door.I'm also considering getting a 20 foot long liner instead of the 15 foot so that I can put it in front of the fireplace and get way more heat from it. This would especially be to my advantage if the blower goes out, considering this is a very old model and the company that made it went bye-bye.
Brick stove and brick mantle. I was thinking about putting it in front of the mantle, on top of something (of course) so it's not directly up against the hard wood floor.The radiant heat from the stove will be strong. Is there a wood mantel on the fireplace or close side walls? Also, the hearth will need an extension that protects the floor out at least 16" in front of the stove door.
Question. Why would it be hard or impossible to connect the liner if it's too far from the fireplace? The angle of the adapter and the connector that I'd get with it, coupled with the strength of the stainless steal and positioning, would make it a perfect easy fit.The all brick fireplace is good however, this is an insert, it's only meant to be installed in a masonry fireplace, not in front. It will be very hard if not impossible to connect to the liner if it's out too far from the fireplace. Don't worry too much about more heat. It will do ok. If the blower goes out, then the motor can be fixed or repaired.
Is this a catalytic model? If so, what condition is the cat in?
Ok, I played around with ChatGPT and this is what it helped me come up with:Note that the mantel is the decorative framework surrounding the fireplace opening. It sounds like the hearth extension in front of the fireplace is what is being described.
This is overthinking it and potentially dangerous. The insert must sit on a 100% non-combustible hearth of at least 8" of masonry. It can not sit on the floor. Install it correctly. Burning dry wood it should perform well.
That will never meet code. Just put the insert in the fireplace as it's designed to be usedOk, I played around with ChatGPT and this is what it helped me come up with:
Basically,
0.75 inches worth of fireproof ceramic tiles on four corners on the floor (directly under where the stove will be) providing the first air buffer.
0.5 inch thick fireproof wood board will be placed on the tiles, and will extend about 8 inches outwards on 3 of the 4 sides (the back of the wood will be pushed up against the front of the fireplace mantle)
On top of that, 4 fireproof bricks (one on each corner where the stove will be) providing an additional 2.25 inch air gap between the fireproof wood and the stove.
ChatGPT:
The proposed method for safeguarding hardwood floors around a wood stove insert involves a careful arrangement that provides a 3.5-inch clearance, addressing a common concern when a wood insert is placed in an open area. This protective setup comprises three essential layers, starting with a layer of heat-resistant ceramic tiles directly placed on the floor. These tiles act as the first line of defense against the stove's heat, ensuring a secure buffer. Above the tiles, a fireproof board is positioned, designed to serve as an additional shield. The key innovation is the fireproof board's extension in all directions, creating a boundary that further distances the radiant heat from the stove and the floor.
The next critical element is the layer of fireproof bricks that tops the fireproof board. These bricks offer both insulation and elevation, with a 2.25-inch clearance between the stove insert and the fireproof board. This design balances the need for protection with practical functionality, allowing for adequate airflow within the liner. This multifaceted approach minimizes direct heat transfer to the hardwood floor while maintaining the wood stove insert's safe operation, even when it's exposed in an open space.
I like this idea. I'm thinking the fireproof wood that will go under the bricks (and above the ceramic tiles), should extend out by at least 12", making the distance in between the front of the stove door and the floor, at least 17-18".The radiant heat from the stove will be strong. Is there a wood mantel on the fireplace or close side walls? Also, the hearth will need an extension that protects the floor out at least 16" in front of the stove door.
There is no fireproof wood that I know of. Masonry, cement, heavy-duty steel studs are non-combustible.I'm thinking the fireproof wood that will go under the bricks (and above the ceramic tiles), should extend out by at least 12", making the distance in between the front of the stove door and the floor, at least 17-18".
Agreed, the insert will heat well enough when properly installed.That will never meet code. Just put the insert in the fireplace as it's designed to be used
Alright, a cement board then.There is no fireproof wood that I know of. Masonry, cement, heavy-duty steel studs are non-combustible.
100% efficient outside the fireplace? No not even close.Alright, a cement board then.
As far as "well enough"... Isn't that relative? This is a 42 year old stove and it is not catalytic. The power goes out or there's an EMP then there's no fan as well. At that point what does well-enough mean? 50% efficiency? Out in the open means 100% efficiency, less wood used and it will heat up more of the house.
Just weighing the pros and cons. I am far from rich. If I were rich I would buy a new stove insert and throw it in there and it would be ridiculously efficient.
You can.buy a used freestanding stove as well. And do you even have room in your chimney for an insulated 8" liner?I bought off of Craig's List for 100 dollars and spent an additional 400 dollars on a UHaul to get it here. I didn't know anything about stoves else I wouldn't have bought it considering it's 42 years old and is not catalytic.
My house fortunately is only 1,100 square feet but it's also high up in the mountains and it can get cold up here in the winter.
New stove sounds great but I wouldn't have bought this one off of Craig's list if I could afford it. Someday I'll be able to get a new one and at that point I'll have to uninstall the 8" liner that I'm about to blow money on, and then install a 6" liner since all the new ones use those.
