Hello!
I started instlaling a Duravent chimney system for my DS machine stove. I started sinking screws only to find they all stripped into the interior drywall (I kept getting longer and longer screws looking to hit that wood board)! Re-inspecting the hole I cut for the thimble reveals my cheap house has absolutely no wood between the studs!
Basically it's made (outside in) aluminum siding, that pink slab insulation, fiberglass insulation, then drywall framed by studs.
I've never seen this before (all the other houses I've had they used wood between studs).
Any ideas how you screw in a 24 foot chimney up the side of a house where the screws have NOTHING to grab on to?
Also, I just realized I installed my thimble around 5" pipe to cieling, so that's another pain I'll have to rotate my siding and lower the hole, I suppose (unless anyone else has any ideas). I'll likely lower the hole 'cause I'm going above code for all parts; this chimney support thing was a surprise (the high thimble hole was just senility/stupidity my wife will love to rake me over the coals unless I can fix it and hide it fast enough!
THanks so much!
THanks so much!
) I was just thinking today; I wonder about that space cinder material you can heat to 2100 degrees and pick up while the other end is under a blow torch (super heat dissapating properties). I wonder about the conduction of different materials (just for brain excercise, not that UL cares).
