They're close but, if you're talking about wood that's already seasoned, I'd give the edge to oak because it seems to put out more heat. The bigger difference is in the c/s/s stage. Hickory starts going punky almost immediately whereas I found that oak can stay good on the ground for years. Oak is also much easier to split, which is an important factor if you split 100% manually. The big downside of oak is that it takes soooo long to dry out.If you have a choice of burning seasoned Oak or Hickory which would you choose? Any why?
Couldn't have said it better myself. Great minds Hasufel, great minds!They're close but, if you're talking about wood that's already seasoned, I'd give the edge to oak because it seems to put out more heat. The bigger difference is in the c/s/s stage. Hickory starts going punky almost immediately whereas I found that oak can stay good on the ground for years. Oak is also much easier to split, which is an important factor if you split 100% manually. The big downside of oak is that it takes soooo long to dry out.
Yep, same here. Especially white oak.I'd give the edge to oak because it seems to put out more heat
This! Hickory here once split gets attacked by some type of boring insect and leaves behind piles of wood dust and they will invade your other stacks so for that reason I avoid Hickory...same thing happens with Hackberry and they are both hard to split...so I stick with White Oak,Hedge and Locust whenever possible.They're close but, if you're talking about wood that's already seasoned, I'd give the edge to oak because it seems to put out more heat. The bigger difference is in the c/s/s stage. Hickory starts going punky almost immediately whereas I found that oak can stay good on the ground for years. Oak is also much easier to split, which is an important factor if you split 100% manually. The big downside of oak is that it takes soooo long to dry out.
Do I have to process it or just burn it? Oak is easier for me to split (hand). Hickory I have here is tough and tends to twist making splitting a pain. Hickory seems to dry a tad quicker and more reliably too. I don't get those sizzlers from my hickory the way I do with oak.
In the stacks the bugs seem to love the hickory and it rots a bit quicker esp until its split. I like the way hickory burns though but the oak is plenty good stuff when dry.
