Thanks for any advice guys.
My home was built in 1989 (2nd owner) and it looks like the Utica boiler that is used to heat my baseboard hot water developed a gasket leak between the burner and the cast boiler. I'm talking about the fiber gasket that seals the burner onto the boiler. At some point part of the gasket failed and now you can see the combustion chamber and fire while running the furnace. It also looks like this created a hot spot inside the furnance and deformed the casting and created a small bulge on the outside of the casting. If I allow it to run for long periods of time, the area that has the bulge will start glowing red hot. That can't be good.
I am not running it at all for obvious safety reasons and I don't have to fix it right now because my primary heat is a wood stove.
1) If I replace the gasket, can I run the furnace? Assuming the gasket face is not distorted and it will seal.
2) For a 2000sqft house with high ceilings, what BTU should I be looking at if I decide to replace?
3) For replacement, roughly, how much should that cost and what brands make sense for a secondary heating solution?
I don't want to cheap out on a solution, but it is unlikely I will keep this home for more than 10 years.
Thanks guys. I can supply pictures if needed.
