Guys,
I had another oil delivery this week and pulled out the spreadsheet. What caught my attention was the amount of oil I was using over the summer which presumably only heated DHW through an indirect DHW tank heated with the oil burner.
From the time we bought the house this summer through our first oil delivery (June 14th - October 24th) we burned 142 gallons of oil over the 134 day period, to give me 1.08gal/day which at $3.54 costs me $3.81/day to heat my hot water. The above calculation of course assumes I didn't use any heat towards October which probably isn't true but I don't know when I first started using heat, so lets round down the numbers in our heads a bit...
This to me seems crazy. Is it possible that I am paying this much just to heat my water? That's almost $1400/year just to have hot water???
Fortunately the oil consumption has been pretty low since installing the insert in November but I am still burning oil to heat the water. That will hopefully change next year when I install a gasser but that is down the road...
So, armed with the above data, what would you do?
1. Switch over to electric?
2. Suck it up until I install a gasser?
3. Tell the wide and kids to take cold showers?
4. Some other option which makes sense financially and keeps the family happy and warm...
If it helps, I have a Veissmann Vitorond 100 with a Reillo burner, running 87% efficiency with the unit being about 8 years old.
All input is greatly appreciated.
Many Thanks,
Bryan
Many Thanks,
Bryan
![[Hearth.com] Oil Indirect DHW - Cost Analysis Help [Hearth.com] Oil Indirect DHW - Cost Analysis Help](https://www.hearth.com/talk/data/attachments/128/128564-a61d183f4548b6645b04d0d9a97c9f02.jpg?hash=XeGnAqO3ZM)
