Most Douglas fir pellets are similar, as are American Wood Fiber Pure White Pine at half the cost more or less ( if they ever come around again). I used to tout the Okanagan DF too but expense went crazy on them. And even if I can't get some of the cleanest burning pellets, my stove is easy enough to clean and the difference in cost is worth saving on my retirement income.Hi, just joined to answer this question even though it's a year old. I ran into it on a hit from a google search for Okanagan Fir, thought my experience might help someone.
I have burned all three brands in my hard to clean. builds up ash too quickly but throws good heat Englander multi-fuel stove. The Okanagan Fir was the hottest pellet I've ever burned and consistently so over three seasons. Also almost the priciest at $360/ton from my local supplier. I've burned over six tons at this point - so more than a small trial.
As I mentioned my stove is a bit maddening in the cleaning department so I've searched through about twenty brands and blends for a pellet that is very low ash and reduces constant vacuuming and upkeep. The Fir is far and away the best I've tried. It cuts my need to clean by a factor of five from a lot of what I consider run of the mill pellets. Very low ash, very little burn pot build up. It has the highest tested BTU/lb I've run across save one other I'm testing now. Unfortunately that one is a ridiculous (IMO) $400/ton at a different dealer. I couldn't resist a quick two bag test though.
The other two pellets mentioned - NEWP and Ok Gold I found to be good to very good although again I only ran two bags of the NEWP so far. Gold I ran a ten bag trial on last year and found them almost as hot as the Fir but considerably ashier for me in the Englander.
