Tools that have more than one use are always the best...I have a few of those lying around, if you know what I mean
 ). And you have to attach the fuel filter after you get it in there.
 ). And you have to attach the fuel filter after you get it in there.Seems like it'd be possible to jury-rig this if worse came to worse. It's just a little hose going from a barb fitting on the carb to the fuel filter inside the tank. The only trick is sealing where it passes thru the hole in the top of the fuel tank.Hopefully nos does not bite you in the behind. Older rubber isn’t designed for today’s fuels and depending on how long it’s been sitting in someone’s shelf the rubber may have already started to degrade significantly. Keep us updated!
Ugg Sounds just like my old small poulan. They don't call it puuuullin for nothing.Argh, so trying to start today (after replacing fuel line yesterday), same behavior: 20+ pulls to start, then runs fine. I'm mystified.
That seems not at all unlikely, except ... if there's enough compression to give decent power once the thing is running, wouldn't there be enough for the fuel pump ? Also, this issue came on fairly abruptly.And if everything else looks correct run a compression test. Maybe the old girl is wore out enough that it won't give a proper impulse for the fuel pump to work correctly
Good old Chevy's ...I've seen old Chevy 350s that you could spin over by the fan and start. Compression is much easier to accomplish than vacuum
Funny, I tried that exact thing just today. And it didn't help. Maybe I overdid or underdid it though.you could try adding a little fuel to the throat of the carb on a cold engine and see if it starts easier then.
No major change.... try opening the spark plug gap up about .005" and see if it helps any.
The 'H' screw they just want 1-1/4 turns from fully-clockwise, so I did that. Didn't do much to the 'L' screw. Wouldn't cause the incredibly difficult starting though, would it ? Here's the relevant manual info ...I may have missed it quickly skimming through but did you adjust the new carb you installed? If not there’s your problem. Especially the hesitation going from idle to speed.
Have you verified the choke (starting position setting ) is working?Ok, thanks for the good explanation. But this wouldn't be causing the really difficult starting, would it ? Especially since when warm the saw restarts on one pull.
 www.madsens1.com
					www.madsens1.com
