Soot issue started last year. Has been fine for 5+ year before that with cleaning, maintaining myself.
I hired a pro to clean and thought maybe I was missing something, but I actually think I cleaned better than he did.
He said if the black soot continues to change ESP or chimney sweep is probably the issue. I did both.
So to sum up steps taken:
1. Replaced ESP x2.
2. Replaced door gasket as seemed to fail the dollar bill test.
3. Swept chimney for blockages.
4. Replaced control board.
Running out of ideas. After replacing the control board it seems to have gotten worse. So I will definitely have to play with feed settings.
Both combustion and distribution fans seem to be working fine.
Used 1-00-06142 control board and set dip switch 6 to on, all others off.
Glass turns black with soot, but heat output seems fine. If anyone has any ideas, it would be appreciated.
Thanks
1. Replaced ESP x2.
Thanks
