I've got an older Mt. Vernon (2005, pre "AE"). I'm hoping someone on here is knowledgeable on these and could provide me with some suggestions. My stove doesn't seem to want to light when it's stone cold. It will dump some pellets in the pot on startup and light them, but it's as if it's not dumping enough in or something. They will light and burn but it seems that the stove doesn't get hot enough to dump more in to get the stove fully going. When it does work, it's after it has been on and off already and maybe there is still some warmth inside, and even then it almost reaches the point of going out. It's an annoying problem because #1 the smoldering pellets stink like heck after the fans all go off and #2 I just know I'm going to go home to a freezing cold house one day with the "call light" on, in fact it happened yesterday.
This stove has a feed rod that you adjust the feed rate with, I wonder if something isn't wrong there either, it's done this with the feed rate jacked all the way up. Also, with the feed rate all the way up, the flame doesn't ever get really tall as I think it's supposed to. The stove seems to burn well once it's fully going with a regular active flame. I've tried a couple of new bags of pellets thinking the leftovers from last year may have had some moisture in them, but it's done it with the new ones too. I've had the feed rate all the way up. I've cleaned it well. I've cleaned the fines out of the hopper (can't or don't know how to clean the auger chute, hard to get to). I did remove the bottom of the burn pot at the end of last year to clean it, it was stuck. I do notice a small gap between it and the rest of the burn pot now (is a small gap normal?)
Any ideas or suggestions would be appreciated, this is a great site with helpful folks, Thanks!
