Harman PF 100 lights, then burning pellets pushed out of burn pot, fire goes out.
Lord Whorfin
13
Vermont
Hello, all. I have a Harman pf100, about 20 years old. Stove was cleaned twice, all airways open. Exhaust sensor and board replaced. can get a good fire going in burn pot, but pellets push the fire out. Switch in manual light, thermostat turned all the way up. Checked for restrictions at air inlet near auger. Chimney pipe clear. All chains visible and working. Status light steady ON. Auto ignition no longer works, there is a bulge in the burn pot.
Dealer cannot figure it out.
To reiterate: Get fire well started in burn pot, but new pellets then push the fire out of the burn pot.
Hope someone can help with this problem.
Thanks for the reply- it was a combination of operator error and bad exhaust temperature probe.Trying to light in Manual, fire started, but no pellets would feed, so I'd switch to auto light, which would then do a full cycle and push the fire out.
You said you replaced the control board. Did you set the DIP switches on it for your PF100?
[Hearth.com] Harman PF 100 lights, then burning pellets pushed out of burn pot, fire goes out.
Thanks for the reply- I followed the instructions that came with the new board for the dip switches.
New problem-it seems like the thermostat is always calling for heat. In manual light, despite thermostat being set at 60 degrees (at least 70 in the house) the fire never goes to a minimum, the main blower is always running.
What color is the exhaust sensor that you replaced? If I remember correctly, the wires should either be red or black. You may have to change dip switch 5.
Hello, FF- probe is black wire, set dip switches per dealer and instructions. I am starting to wonder if the dips are set correctly.
Another data point- I tried disconnecting the therm wires at the furnace. Got 4 blinks (therm not connected), let it run for an hour, and still would not cool off.
Here is a link I found once to double check. Black is the old style probe. You might want to try a red wire one.
If you try a different ESP probe, make sure and buy on OEM probe, not an aftermarket one. In the past, people were having issues with the aftermarket ones.
Did you try taking out the old probe and wiping it off with steel wool?
You may want to take a look at this :
Thanks for the reply- that was it, I installed a new ESP, now lights fine. However, new problem-thermostat does not have an effect on heat level. Puts out constant heat, no matter whether thermostat is at maximum or minimum.
Open up your thermostat and try disconnecting one of the T wires while it is running. That is all low voltage. If you can get a picture of what's inside the thermostat. The LED is fed from two wires, the other two wires I'm not sure what they are attached to.
Thanks for the reply, Whiteknucker: I tried disconnecting the thermostat wires where they connect to the furnace- there was no discernible change for over an hour, then reconnected them. One other thing I noticed- Switch from Manual light to Auto light, and the status light went off, which i interpret as the thermostat not calling for heat. Thermostat was set to Minimum at this time. I have not experimented further. Another note- auto light no longer functions, due to bulge in the fire pot that keeps the igniter from making good contact with it.
I'm not really sure what's in that remote thermostat. Disconnecting the wire should make the stove go to idle or shut off as you would not be calling for heat. I'm not sure how the temperature dial on the control card works in conjunction with that remote dial. The igniter is mounted in what I call the "igniter cavity), the one that needs to be cleaned out an vacuumed. It would be mounted on a standoff bracket and would not be touching anything. The heat from the igniter would then rise and ignite the pellets. Again, I have a P43 stove so not sure about this "furnace".
Thanks-It's weird-my tech is good with Harmans, bought it from him 20 years ago. He is baffled. I'll post a reply to you when/if I figure it out
If the furnace is set to manual, the pellets keep feeding and the blower should be running. The only way it would shut off, is if it is in automatic.
The thermostat is just an on / off switch. Two wires from the furnace should go to the thermostat. That's how it is on my P68 anyways. There may be other wires, but they shouldn't stop your unit from running. Pull the front of the thermostat off, write down where they are landed. The two that go to the thermostat, twist them together, you are now calling for heat, the fans and pellet feed should be working. Untwist them and the unit should stop feeding as it is in manual. There should be a fan going until everything cools down.
You need to replace the auto igniter to get your unit running properly, that's not helping your problem.
You've had your furnace for 20 years, you know much more then I do, but I've got close to 20 years with my P68 and there are similarities. Hope your making progress. And being a licensed electrician since 1973 helps,(but not all the time).
Good Luck
Tom
On my P43, the room blower will turn off while the stove is running. In stove mode, this happens at a certain heat setting (below 2?). In room mode it happens when the temperature selected is low compared to the room temperature. In the spring and fall(or summer as mines in the basement) I run room mode, igniter manual (so it will idle),and then turn the temp dial all the way down. Then I get a small flame with only the combustion blower running. The PF is a different design as it uses that remote thermostat. The control board was designed around the probe (thermistor) that is usually hooked to the back of the stove. I guess on a furnace you don't care about the temperature where the furnace is, so they moved the probe into the remote thermostat with a dial as well.
It seems with an AI search ect and the instructions that inside the box is a thermistor and a POT in series to bias the thermistor. It then somehow interfaces to the standard temp dial on the control card. The setting on the control card should be "normal".
Since the OP does have a working igniter, he must be in room mode, igniter manual or service mode (which is like stove mode)
OP - I think there was a different igniter used in that furnace. Most of us have not heard of a pressure igniter, only finned. You may have to install a finned one with a new control board.
Edit - Also this RPM choice is confusing. Do you know what RPM type it is? What was the control board part number and the new board part number? This might be a good time to try the original board.
  • [Hearth.com] Harman PF 100 lights, then burning pellets pushed out of burn pot, fire goes out.
