Older stove recommendations
That's OK, I'm glad we're clearer on a few issues. Yes, I do not want a cat stove, however great they may be. Next month, I'll be hitting the market for what's out there. I want to come back in when I find a few potential gems and get some feedback. A lot will depend on the pass and what the spring weather brings. Some years, it's pretty horrible until May, and then it's smooth sailing except for rain.
There is a long and well-documented history of the basic F118 regarding baffle warpage. A guy did an entire rebuild, taking the stove apart and buying/installing new parts. Very detailed with pics, and I don't mind that a bit because at least I know I'll rebuild it correctly. Bolts breaking are part of the deal in cast anything that got hot. I really like the looks of that model, but I'm open to the many others that have been mentioned, which will be EPA stoves, just not cat.
I'll put together a list of what's been mentioned and compare it to what's for sale. Thanks for all the input so far!
Kevin
I have used cat and non cat epa stoves and cats have their up sides and down. Absolutely nothing wrong with noncats
Reactions: Real1shepperd
I took a look at what is available in the Spokane/Walla Walla area. There is a lot of not great stoves listed. Watch out for the Taiwan knockoff there. I saw the F118CB out of Walla Walla if that is the one you looked at. I would pass. They did make improvements around 2016 on this stove that helped reduce the secondary rack warping, but the age of this one is unknown.
This is a fairly decent stove. It's a non-cat EPA stove. Needs a new set of firebricks, but the price is good.
any stove you buy will need a rebuild. so don't forget that too. they are very heavy and just to take them off the hearth and that will break most seals
Well the very lightly used jotul f400 made it back from Boston to NJ in my crv after i took it apart to transport and fit it in the crv.
I did not tear it down for a rebuild/reseal. That was 2019. Been great runner with no real problems and no leaks at all.
This was a "like new" stove so that for sure helped. Paid $1,400 in 2019 dollars.
I may have run a few spots of furnace cement or whatever the recommended seam sealer was (probably rutlan) at the reassembly time when i got it home. I think a few small spots came loose and just needed a simple fill in those couple spots.
