What are you venting with your linerI'm sure there are others, but here are some that sell the 304 Class A insulated pipe, if that was what you are looking for, if you need the 304L flex liners I'm sure any of these places can get them if they don't stock them, many may have the 316ti flex liners. What are you venting with your liner
http://www.hartshearth.com/ProductCart/pc/viewCategories.asp?idCategory=785
http://www.fireplace-chimneystore.com/ventis-316l-stainless.html
https://www.cjshearthandhome.com/ventis
https://www.cheapchimney.com/products/ventis-class-a-all-fuel-system-316l-stove-pipe
http://www.stove-parts.net/Ventis_Chimney_s/144.htm
https://www.rockfordchimneysupply.com/rock-vent-class-a-chimney-systems
http://www.woodlanddirect.com/Chimney/Chimney-Systems
I looked at their site. I didnt see olympias heavy flex (armor flex) but they have copperfeilds heavy wall which is great liner and is even thicker than olympias. They also have olympia hybrid liner which is inbetween heavy wall and light wall. It is stillI'm sorry - I should specify I am looking for a heavy flex liner.
Yes it is absolute junkIs the smooth wall 2 inner linings the stuff i should stay away from? For example...
https://www.rockfordchimneysupply.c...exible-stainless-steel-chimney-liner-only.php
because the bottom edge of the inner layer is completely unsupported. it tends to kink when bent to hard and then gets caught on the brush when cleaning. Any of the light wall smooth inner wall flexible liners are not worth installing in my opinion. If you want smooth wall go with heavy or mid weight liners for flex or rigid.I don't quite understand why the smooth double wall flue pipe from Rockford is junk? The smooth wall is an attractive feature to me at least it is something I "think" would be good.
Is the double smooth wall from DuraVent also junk? I've never had a harder time making a purchase than buying flue pipe for my stove.
Yes that is exactly the same products we use. They just relabel them from olymia to champion.Thanks for the quick response. Just got off woodland direct and I found the Champion heavy flex liner kit with insulation and tee and everything else for $910. The thickness was .018 and it appears to be smooth wall flex that I was looking for. I could then transition to the Champion class A when exiting the chimney to get above roof line.
Would this be a good quality liner you would recommend? Thanks in advance. I value your opinions.
