operate a quadrafire manually
versys
2
Sellersville,Pa
I just installed a santa fe quadrafire , I had a Lopi which was able to be operated manually and thats what I'm used to, can a quad be operated manually by jumping the? thermostat with a switch between and using the heat output switch manually to control out put? Would this create any problems or issues? Thanks for your thoughts. I'm used to running the stove at a slow steady level instead of using a thermostst
Former Farmer
672
NE Wisconsin
A standard switch will work just fine. It will not cause any problems with the stove. Run a 2 wire from where the thermostat would connect to on the stove to the switch.
A thermostat is just a switch, that opens and closes for you.
Reactions: Ssyko
versys
2
Sellersville,Pa
Thank you, that's what I thought but wasn't sure if it would cause any problems with the stoves electronics, the stove is brand new so I wouldn't want to mess it up. I prefer to run the stove slow and if it gets to warm I shut it down , not crazy of the stove constantly starting and stopping, thanks again!
