Heres mine
![[Hearth.com] Opinions on an ATV Trailer [Hearth.com] Opinions on an ATV Trailer](https://www.hearth.com/talk/data/attachments/142/142649-22850dd572c39f02021e9a0f9487d068.jpg?hash=62bwEatcko)
I use a polar with side extensions also. They dump and swivel and the new models have tandem axles that follow the ground for a smooth ride. Plus the weight capacity of Polars are impressive. Mine is rated at 1500 pounds.Here's my Polar loaded with mostly Oak and Black Locust.
View attachment 142684 View attachment 142685 View attachment 142686
I'm seriously considering a "buy once - cry once" purchase for this. I have 80+ acres of rough wood lot to harvest from and I need something the same width as the tractor/ATV, that can haul a good amount of heavy wet wood, and do it on uneven ground.
http://www.mountaingoattrailers.com
Question for you guys with the Polar trailers....how thick is the plastic, and do you see it cracking while tossing logs in when it's freezing cold out? I've got an old metal trailer that I pull behind my garden tractor, and it's about rusted through and ready to be replaced and I like the design and price of those Polar units, I'm just a little worried about plastic.
The plastic is good and thick. It's cold where I live and I've never had a problem with it cracking as of eight years now. Without a garage mine has been left outside and no problems there either. I did change my coupler to a ball coupler. It came with a pin coupler.Question for you guys with the Polar trailers....how thick is the plastic, and do you see it cracking while tossing logs in when it's freezing cold out? I've got an old metal trailer that I pull behind my garden tractor, and it's about rusted through and ready to be replaced and I like the design and price of those Polar units, I'm just a little worried about plastic.
The ohio steel model is half the price and holds $750 lbs, no plastic cracking it is heavy duty. I highly doubt you will be carrying more weight than that on a small trailer, I have never had an issues and over 20 cords of wood. It other words, I have been very happy.
