we're in a 1940 fixer-upper with stone exterior walls on the first floor and wood frame on the small second floor. poorly insulated at the moment and that's something we'll be spending money and time on in the coming year or two, along with replacing a large single-pane window in the living room.
roughly 1700 sq ft interior space
main fireplace dimensions;
49"w x 34"h at the front
tapers back with steel firebox, 24" deep at 24" high
short, floor-level hearth extends just barely 16"
chimney is 18' with exterior exposure
only existing heat source is 5 mini-splits that really struggle when temps get below freezing, and a combination of electric and propane space heaters. there used to be a forced air oil burner but it was long since dead when we moved in. last winter we just closed off the living room and office portion of the house (as well as guest bedrooms) and still struggled to keep it near 60f when it got really cold out. we're generally fine with low to mid 60's, though it'd be nice to be able to get it warmer, for guests and such.
there are two chimneys and three flues, all of which have loose and damaged tiles and will need to be re-lined. at the moment i'm only focusing on the main fireplace in the living room to get us some heat before this winter is over. kinda late to be getting started, but cash flow, fixer-upper, blah blah. right now it looks like we won't get a liner til around the end of January. i'm not doing the liner myself, though i may do some prep like cutting a clear 6" path through the throat/damper.
there is an old insert with an 8" exhaust/liner that has been more crushed than ovalized to make it through the damper, and apparently ends right above the the smoke shelf. the insert may or may not be sound, but it isn't safe to use in its present configuration, with the flue in the condition it's in. i don't know if it's worth saving this insert to use in the second fireplace later on.
i'm attaching rough diagrams of the first and second floors. the living room, where the main fireplace is, has a cathedral ceiling. the door to the rest of the house opens at the bottom of the staircase leading up to the second floor.
questions: does this look like a viable floor plan for effectively heating most or all of the house with a properly sized insert in the living room?
i admit i'm getting a bit overwhelmed looking at brands and model specs, but strictly by the numbers i'm having a hard time finding anything besides the 2400 with the same (apparent) bang for the buck. the only downside i can see is that it isn't anywhere near flush and i'm not wild about using a mat. are there other, comparable inserts at a similar price i should look at?
so far i'm not seeing too many faceplate options big enough for this fireplace.
brevity vs thoroughness . . . sorry to be so long-winded.
