How tall is your chimney2300 model and shutting the air down an night for a overnight burn I think it is burning too fast.okay to cover this quater size hole with some metal tape to slow the burn down
That is not very tall you should not have excessive draft. What temps are you seeing both pipe and stovetop? When do you start to shut back?5 ft of double wall and 9 ft supervent
What temps does the stove run at once shut back?Shut back at 350 stove top.its getting too much air.with tape over this hole there seems to be adequate air .
Then it is not getting too much air. 350 is low for stove top temp
True with all modern EPA stoves. That is to prevent smoldering the fire.In the top of the picture I posted the air intake is closed and you can see at the top there is still a gap that lets a fair amount of air .just saying.
It does not close all the way that's why I thought plugging that hole would slow the low burn down a little but not smoother the flames.i will experiment with a full load when it gets colder and report backIt doesn't look like the draft blade is closing all the way. I'm comparing it to a drolet BalticII. Mine looks identical to that one. Also I think this stove has a top heat shield so the STT are about 100deg lower so 350 is around 450. 350 to 450 is a good cruising temp.
Thanks for the info.for some reason mine was slightly bent and not closing as in the first picture.got her straightened out and just the half moon and hole now.cheersYou might want to check with Osburn and verify that it's in the closed position. Drolet and Osburn have their similarities but I would make sure first. Mine closes all the way so air can only go through the round hole and the half moon hole.
Talked to sbi tech support and the air intake was not closing all the way.mine is bent.getting a new one.picture shows what it should be like.You might want to check with Osburn and verify that it's in the closed position. Drolet and Osburn have their similarities but I would make sure first. Mine closes all the way so air can only go through the round hole and the half moon hole.
