Hello all! I think I've finally mastered my burning tecniques with my Oslo. Only a couple of problems so far. One is a clearance issue from a non-combustable wall for my corner install. Specs 9" min clearance which is where I'm at but one of the walls still gets too hot for my comfort now that I'm burning the stove hotter. I think I've got a solution for this though by using a sheet stainless steel electric range backing I had on hand between the stove and the wall. Other than other suggestions for that, my two questions are:
1. I'm using good seasoned wood now that lights and burns well (didn't start off this way) but I still occaisionally hear a small piece of creosote falling down inside the chimney when I'm getting the stove up to temp. Is this normal to hear from time to time?
2. I'm using a fan maybe 12 feet from the stove pointed towards it to blow off the hot air and circulate it through the house. Because I have a stove top oven on the top of it I've placed my temp guage on the side and found it to read about the same as it did on the top. Now the difference in my temp reading from no fan to having the fan on is about 100 degrees lower. Do I ignore the fact that the fan lowers the temp reading and shoot for the "optimal" burn temps or do I need to take into consideration the lower temp reading due to the fan and burn accordingly? I know alot of you also use fans so I'm wondering how you approach this.
Cast Iron and steel tend to move around when things get hot and cool down!
